| Wiring upgrade http://ducatipaso.org/forum/viewtopic.php?f=1&t=1995 |
| Author: | zedder [ Wed Sep 19, 2007 4:28 pm ] |
| Post subject: | Wiring upgrade |
Hi John, just tried your upgrade with relays, but without success. All circuits went dead! I've gone back to standard and although I now have power restored, I still have the original non-starting problem. My bike differs slightly from yours, in that it has TWO coils, one on each side rail. Would this make it unsuitable for your mod? Cheers Steve |
| Author: | jcslocum [ Wed Sep 19, 2007 11:49 pm ] |
| Post subject: | |
Nope, they are the same. I have 2 coils too. You had no power at all? |
| Author: | zedder [ Thu Sep 20, 2007 12:17 am ] |
| Post subject: | Dead Paso |
Hi Jon Absolutely dead as a DODO! No power to instrument console,no sign of life at starter solenoid, not even a click! I'm certain I followed your instructions, I had the print-out beside me as I worked. The coils were the only difference to your photos, I just made up a "Y" wire and put one on each coil and took the ORANGE wire to the relay (terminal 86 ?) I got the relays from a local autoelectrician who assured me they would be OK after seeing your upgrade print-out (which I left with him for reference to get my order ready). They are not genuine Bosch, they are Guardian GR7 12V- 40A/15A. Do you think they could be the cause? If it stops raining I may venture out and have a look at the starter motor as the solenoid makes a healthy "click" when the starter is pressed but even with the kill switch off and a leisure battery jumping it it wont turn over at all !! [/i] Steve |
| Author: | paso750 [ Thu Sep 20, 2007 9:52 am ] |
| Post subject: | |
hmm, it`s actually hard to make a mistake... G. |
| Author: | Finnpaso [ Thu Sep 20, 2007 12:23 pm ] |
| Post subject: | |
