Rear wheel axle question http://ducatipaso.org/forum/viewtopic.php?f=1&t=2058 |
Page 1 of 2 |
Author: | ducapiero [ Fri Oct 26, 2007 1:32 pm ] |
Post subject: | Rear wheel axle question |
Hi guys i bought a 750 ss rim,and as i said before i'm planning to swap to 17 wheel on rear,now the question is what are the size of the wheel axle??? i have to machine a new one but i don't have the measure.... :confused: :confused: many thanks Piero P.s. i'm mounting also a steering dampner of a 999 and 4 piston brembo caliper with radial pump :thumbup: :thumbup: |
Author: | paso750 [ Fri Oct 26, 2007 5:15 pm ] |
Post subject: | |
if I recall correctlz its not necessarz to make a new axle. Its possible to use a new one, but you need different bearings and a new spacer. I may be wrong but when I thought about doing that years ago I think this would have been one of the first steps. G. |
Author: | Desmo_Demon [ Fri Oct 26, 2007 6:33 pm ] |
Post subject: | |
What year is the SS rim? If it is an early 90's rim, it probably is already for a 17mm front axle and a 20mm rear axle. If it is a newer rim, it is for the 25mm axles. If this is the case, as Gerhard states, you will need to replace the bearings and center spacers for a 17mm front and 20mm rear axle. |
Author: | ducapiero [ Sat Oct 27, 2007 12:02 am ] |
Post subject: | |
:confused: :confused: :confused: mmmi don't understand why new bearings??? i'll investigate on the year of the rim and i give you notice when the rim arrive...... lamps Piero |
Author: | ducapaso [ Sat Oct 27, 2007 7:06 am ] |
Post subject: | |
Author: | paso750 [ Sat Oct 27, 2007 4:07 pm ] |
Post subject: | |
Author: | ducapiero [ Mon Oct 29, 2007 10:38 am ] |
Post subject: | |
Author: | Desmo_Demon [ Mon Oct 29, 2007 2:44 pm ] |
Post subject: | |
Author: | ducapiero [ Fri Nov 09, 2007 5:00 pm ] |
Post subject: | |
Author: | Desmo_Demon [ Fri Nov 09, 2007 7:01 pm ] |
Post subject: | |
Author: | ducapiero [ Sat Nov 10, 2007 11:34 am ] |
Post subject: | |
Author: | ducapaso [ Sun Nov 11, 2007 8:12 am ] |
Post subject: | |
Author: | ducapiero [ Tue Nov 13, 2007 6:27 pm ] |
Post subject: | |
Author: | Desmo_Demon [ Tue Nov 13, 2007 6:34 pm ] |
Post subject: | |
Author: | ducapaso [ Tue Nov 13, 2007 6:36 pm ] |
Post subject: | |
Page 1 of 2 | All times are UTC |
