ducatipaso.org • View topic - Question about 750 rear shock
It is currently Fri Jun 19, 2026 5:44 am
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Question about 750 rear shock
PostPosted: Wed Oct 31, 2007 5:37 pm
I am lucky enough to have bought a box fresh - unused rear shock (Marzocchi) for the 750 Paso. Just one question about adjustment. I know I can alter compression and rebound damping but the preload looks to be fixed. Can this be adjusted? I don't expect to have to do this but it is always nice to know.
PostPosted: Wed Oct 31, 2007 7:52 pm
I have Öhlins in my 750 Paso, but at least i can adjust spring preload in my 907IE Marzhocci, what is "later version", than 750 Paso & 906 Marzhocci. In my unit read "Duo Remoto" in that compression adjusting part. I know, 750 unit was different, than mine. Witch modell U have?
 Post subject: 750 rear shock
PostPosted: Thu Nov 01, 2007 10:29 am
PostPosted: Tue Nov 06, 2007 5:28 pm
Here it is
PostPosted: Tue Nov 06, 2007 5:59 pm
JWilliam, you can preload the spring twisting this two rings what there are in upper part of the shock. This rings could be screwed one against the other to be fixed. There is a tool to do it, it is like a hook.
70 hp. can change the world
PostPosted: Tue Nov 06, 2007 7:56 pm
PostPosted: Wed Nov 07, 2007 3:30 am
PostPosted: Sun Nov 11, 2007 6:40 am
PostPosted: Sun Nov 11, 2007 10:36 am
PostPosted: Sun Nov 11, 2007 1:32 pm
PostPosted: Sun Nov 11, 2007 3:11 pm
PostPosted: Sun Nov 11, 2007 4:20 pm
PostPosted: Sun Nov 11, 2007 7:51 pm
PostPosted: Sun Nov 11, 2007 8:04 pm
PostPosted: Sun Nov 11, 2007 11:37 pm
All good info. Antti, thanks in advance for researching the reservoir pressure, and the exact kit for the 750.
Dave
Users browsing this forum: No registered users and 29 guests
