ducatipaso.org :: View topic - Newer Engine Swaps for the Paso 750
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=1&t=2088
Author:  Desmo_Demon [ Tue Nov 06, 2007 6:55 pm ]
Post subject:  Newer Engine Swaps for the Paso 750
What have been people's experiences with installing newer engines into their Paso 750?
The reason that I ask is that I recently picked up a 916 engine from an ST4 that came with the throttlebodies, wiring harness, computer, and airbox with K&N filter......
I bought this at a reasonable price with the idea that I could install it in my 748, ST2, or the spare Paso 750 frame that I have for a future project. I went to install it into my Paso rolling chassis...
...to limit the amount of space that the engine would take up, and I noticed a few things......
1) The mounting points on the engine between the cylinders and at the top of the rear of the cases were 1-3mm too wide on either side.
2) The mounting points on the engine at the bottom rear of the engine cases are too wide by close to 3-7mm on each side.
3) The mounting points for the swingarm on the engine cases are considerably wider on the ST4 engine. Probably 15-25mm on each side.
4) Looking at the engine on my 748, it looks like the swingarm mounting section of the 748 and Paso engines are of similar widths.
Anyway, I was just curious as to any issues that others have had in installing a newer Ducati engine into a Paso 750 and what you ended up modifying.
Author:  Finnpaso [ Tue Nov 06, 2007 8:00 pm ]
Author:  Desmo_Demon [ Tue Nov 06, 2007 8:34 pm ]
Author:  Marinus [ Wed Nov 07, 2007 3:25 am ]
Author:  ducapiero [ Wed Nov 07, 2007 10:57 am ]
Author:  Tamburinifan [ Wed Nov 07, 2007 11:36 am ]
Author:  Desmo_Demon [ Wed Nov 07, 2007 1:48 pm ]
Author:  paso750 [ Thu Nov 08, 2007 10:52 am ]
Author:  Desmo_Demon [ Thu Nov 08, 2007 1:35 pm ]
Author:  Finnpaso [ Thu Nov 08, 2007 8:16 pm ]
Author:  Desmo_Demon [ Thu Nov 08, 2007 8:22 pm ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
