906 907 bodywork on 750 http://ducatipaso.org/forum/viewtopic.php?f=1&t=2158 |
Author: | Stefano [ Mon Dec 03, 2007 9:36 am ] |
Post subject: | 906 907 bodywork on 750 |
Is it possible fit 906 or 907 bodywork on 750? ![]() |
Author: | paso750 [ Mon Dec 03, 2007 11:06 am ] |
Post subject: | Re: 906 907 bodywork on 750 |
906 body work will fit but as it is watercooled the radiators are bigger. Vice versa you would need to cut the opening of the side fairings where the radiators are stuck in if you would try to use 750 fairings on a 906. At least that is what I was told, never did that myself. As far as I know the 907ie uses the side fairings of the 906, although it has the radiator on the front. Rear and rear side panels are interchangeable. Using 907ie screen requires different foam surround of the instrument panel. Gerhard |
Author: | persempre907 [ Mon Dec 03, 2007 3:38 pm ] |
Author: | Finnpaso [ Mon Dec 03, 2007 3:42 pm ] |
907 and 906 fairings are quite different ones(also compared to each others, mainly in front part)... I think, its quite complicated to swap another fairings to 750 Paso,but surely can be done with fiberglass jobs. I have done one 906 front fairing from fiberglass for dual headlights to my 906 friend. He is satisfied to my work.. ![]() ![]() |
Author: | paso750 [ Mon Dec 03, 2007 4:14 pm ] |
Author: | Finnpaso [ Mon Dec 03, 2007 4:38 pm ] |
Sorry, i remembered wrongly, only difference is that spoiler system in front fairing. I mixed things: I mixed 750 front fairing to 906/907 fairings... My mistake! ![]() |
Author: | paso750 [ Mon Dec 03, 2007 5:15 pm ] |
he he, you were about to make me sweat ![]() G. |
Author: | Finnpaso [ Mon Dec 03, 2007 5:24 pm ] |
Author: | persempre907 [ Mon Dec 03, 2007 7:24 pm ] |
Antti, you only have to have a little less ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Ciao |
Author: | Finnpaso [ Mon Dec 03, 2007 8:36 pm ] |
Frankie dear, as I told, i start to be old man and i havent had time "to enjoy" so much in my life(cause spent too much time with Ducatis, making big house, etc...), so i think ill take just right amount of ![]() ![]() ![]() |
Author: | persempre907 [ Tue Dec 04, 2007 12:10 pm ] |
