ducatipaso.org • View topic - Clutch help needed
It is currently Thu Oct 02, 2025 1:55 am
 Post subject: Clutch help needed
PostPosted: Wed Dec 26, 2007 9:02 am
Hi all,
Can anyone supply me with the measuraments of the mushroom-like part located on the clutch slave cylider? the stem goes in the bearing, and is 8 mm. diameter, the rest - I don`t kow of. I guess that the "mushroom" head should be approx 15 mm. diameter, since it`s in contact with the pressure plate that has approx. same contact area.
I`ll appreciate your help!
Thanks in advance,
Eli
 Post subject: Re: Clutch help needed
PostPosted: Wed Dec 26, 2007 10:43 am
PostPosted: Wed Dec 26, 2007 12:45 pm
Thank you very much!
Eli
PostPosted: Wed Dec 26, 2007 5:22 pm
there're various kind of those pins: they can be steel or brass, the top diameter can be 16mm or smaller, in the lower part of the top there might be a sort of step to leave a clearance with the rubber gasket of the bearing and let the pin touch only the inner ring of the bearing... Italian handcrafters aren't so hardly connected to the standard models! ;)
Users browsing this forum: No registered users and 93 guests
