| 750 Paso front brake adapters to swap 320 rotors to M1R http://ducatipaso.org/forum/viewtopic.php?f=1&t=2224 |
Page 1 of 4 |
| Author: | Finnpaso [ Tue Jan 08, 2008 12:57 pm ] |
| Post subject: | 750 Paso front brake adapters to swap 320 rotors to M1R |
Have anybody done such adapters to 750 M1R fork with 4 piston "black" Brembos, or "gold line" 4 piston Brembos??? Now i have normal cast iron original 280mm rotors with adapters to 4 piston black Brembos, but planning in future 17" conversion with same calipers to original M1R fork, but with 17" wheel and 320mm rotors. All info will be welcome |
| Author: | ansim [ Tue Jan 08, 2008 3:26 pm ] |
| Post subject: | Re: 750 Paso front brake adapters to swap 320 rotors to M1R |
I have made a set for 65mm spacing. Link to picture: |
| Author: | paso750 [ Tue Jan 08, 2008 3:54 pm ] |
http://www.box.net/shared/lscrqbkkbx (also with 65mm brakes) Ansim, the Autocad file download doesn`t work. Can you fix it or send me the file ? I would like to add this info to the downloads if you don`t mind. G. |
| Author: | ansim [ Tue Jan 08, 2008 4:41 pm ] |
Here is the autocad file in Autocad2000 version, NOTE: This adapter is for orginal Oscam wheel with 280mm rotor and orginal M1R fork. Sorry for this. Remembered wrong. Here are link to photos with mounted adapter on my Paso. edit 2008-01-09 09:58: Not Brembo, Oscam |
| Author: | Finnpaso [ Wed Jan 09, 2008 8:33 am ] |
Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork. |
| Author: | ansim [ Wed Jan 09, 2008 9:11 am ] |
It seems to be very tight with a 320 rotor/disc and 16" wheel. See my pictures with 280 rotor, It's tight with 4piston Brembo/280 rotor and a bigger rotor/disc will probably make it more tight. I doubt that a 320 rotor won't fit at all. But with a 17" wheel it will be ok, as you plan, Finnpaso. With some measurement the adapter can be modified to fit a 320 rotor/disc. |
| Author: | persempre907 [ Wed Jan 09, 2008 11:08 am ] |
| Author: | ansim [ Wed Jan 09, 2008 12:47 pm ] |
Nope, it's still the 280mm rotors and 16" wheel. Check these pictures, But it is not so tight with 40mm spacing calipers. |
| Author: | persempre907 [ Wed Jan 09, 2008 2:10 pm ] |
| Author: | paso750 [ Wed Jan 09, 2008 6:34 pm ] |
guys, if you just check what I posted. That`s a M1R fork with 17" wheels, 320mm discs and 65mm Brembos + adapters. Antti, it seems not clear, do you want to switch to 17" with these brakes or keep the 16" ? G. |
| Author: | ansim [ Wed Jan 09, 2008 8:01 pm ] |
True G. They looks great and it is an approved mod .
| Author: | jcslocum [ Thu Jan 10, 2008 11:41 am ] |
A, Can we get an update on the Mega Squirt install??? |
| Author: | Finnpaso [ Thu Jan 10, 2008 1:22 pm ] |
Surely i make same time 17" conversion with original 907 wheels, so i meant 17" Ducati rim. |
| Author: | Christian [ Tue Jan 22, 2008 7:51 pm ] |
Hi, I have done adaptor for M1R forks with 17" wheel and 320 mm rotor. See http://zattol.com/perso/download_f.html Bye |
| Author: | Finnpaso [ Thu Jan 24, 2008 4:43 pm ] |
I mean adpters for OLDER black coloured 4 pistons, or OLDER golden line Brembos WITH 40mm hole distance. Those Yours are for newer calipers... |
| Page 1 of 4 | All times are UTC |
