ducatipaso.org • View topic - Changing front part
It is currently Wed Mar 11, 2026 3:00 pm
 Post subject: Changing front part
PostPosted: Sat Jan 12, 2008 5:30 pm
year: 1985
Hey guys i have half finished my swingarm transplant from a 907,i need only a wheel axle and a brake support,but today i found a vomplete front part from a benelli tnt and i completely fall in love :banghead: :banghead: :banghead:
it will be so diifficult to mount,i reeat it .s complete wheel front clams brake etc etc,and the price is so good :smoke: :smoke:
give me suggestions i need it
lamps
Piero
 Post subject: Re: Changing front part
PostPosted: Sat Jan 12, 2008 6:08 pm
everything is possible.
Using front discs and rim is for sure not a big issue. This starts if you want to use the radial brake calipers. These will require a special adapter.
If you can get the whole fork you`ll have the problem that the fork tubes will have such a large diameter that you won`t be able to steer unless you cut off the front edge of the tank.
This I know as I have a Laverda fork laying here. Next to that the geometry of the triple clamps is probably different, the steering axle will be too long etc etc
PostPosted: Sun Jan 13, 2008 7:20 pm
If I can remember, the "bucefalo" is a street figter, without fairing, so you'll need a complete front suspension, I mean both triple clamp, forks at least, and a useful rim, brakes, handles and so on.
If you have such parts, it'll be possible to do, just adapting the steering axle (maybe you'll need only a pair of bearings and a spacer, otherwise... :banghead:
Se mi ricordo bene, il bucefalo è uno street fighter, senza carene, così avrai bisogno soprattutto delle piastre di sterzo e degli ammortizzatori, più la ruota completa (basta che ci vada), i semimanubri e tutto quanto.
Se hai tutto il necessario, dovrai solo adattare il perno di sterzo (magari bastano 2 cuscinetti adatti e uno spessore), altrimenti... :banghead:
PostPosted: Mon Jan 14, 2008 9:05 am
PostPosted: Mon Jan 14, 2008 11:06 am
year: 1985
Thanks guys,but i noticed that Gerhard hit the problem..... to little space between fork tube and tank :banghead: :banghead: :banghead: ......
no matter it's a good reason to spend my money for a better part :thumbup: :thumbup:
lamps
Piero
PostPosted: Mon Jan 14, 2008 1:29 pm
I will try my other fork one day and I also have an old dented tank to test with. The edge needs to be cut away and then rewelded. Maybe in summer ...
PostPosted: Mon Jan 14, 2008 2:04 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Jan 14, 2008 2:53 pm
year: 1985
:dunno:
my problem about axle is that i have a rim 4.5 with 17mm of innner diameter but i think i can use only axle from 907 or m 900,the other are not long enough,but as you said i noticed that this type of axle are 20 mm of diameter :banghead: :banghead: :banghead: .......
i hope i don't have to machine the hole of my rim :smoke: :smoke: ....
PostPosted: Mon Jan 14, 2008 4:16 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Jan 14, 2008 5:47 pm
year: 1985
Demon the problem it's not the bearing but the rim's hole.....
give me notice when you check your rim...
lamps
Piero
PostPosted: Wed Jan 16, 2008 2:25 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Jan 16, 2008 10:41 am
All early 17 wheels on 851/SS/907/888/Monster have same axles,
20mm front & 17mm rear.
But locking nuts on my 907 is 24 mm & 22 on my Monster.... :?
Think the bracket from a Monster will fit, not so sure about the caliper fitting.
PostPosted: Wed Jan 16, 2008 9:59 pm
year: 1985
thanks for the answers guys,today i find an axle from a monster 600,it is 17 mm of the diameter and 330mm of lenght,i think the sizes are ok.... :smoke: :smoke: :smoke: :smoke:
what do you think??
lamps
Piero
