| Changing front part http://ducatipaso.org/forum/viewtopic.php?f=1&t=2239 |
| Author: | ducapiero [ Sat Jan 12, 2008 5:30 pm ] |
| Post subject: | Changing front part |
Hey guys i have half finished my swingarm transplant from a 907,i need only a wheel axle and a brake support,but today i found a vomplete front part from a benelli tnt and i completely fall in love it will be so diifficult to mount,i reeat it .s complete wheel front clams brake etc etc,and the price is so good give me suggestions i need it lamps Piero |
| Author: | paso750 [ Sat Jan 12, 2008 6:08 pm ] |
| Post subject: | Re: Changing front part |
everything is possible. Using front discs and rim is for sure not a big issue. This starts if you want to use the radial brake calipers. These will require a special adapter. If you can get the whole fork you`ll have the problem that the fork tubes will have such a large diameter that you won`t be able to steer unless you cut off the front edge of the tank. This I know as I have a Laverda fork laying here. Next to that the geometry of the triple clamps is probably different, the steering axle will be too long etc etc G. |
| Author: | ducapaso [ Sun Jan 13, 2008 7:20 pm ] |
If I can remember, the "bucefalo" is a street figter, without fairing, so you'll need a complete front suspension, I mean both triple clamp, forks at least, and a useful rim, brakes, handles and so on. If you have such parts, it'll be possible to do, just adapting the steering axle (maybe you'll need only a pair of bearings and a spacer, otherwise... Se mi ricordo bene, il bucefalo è uno street fighter, senza carene, così avrai bisogno soprattutto delle piastre di sterzo e degli ammortizzatori, più la ruota completa (basta che ci vada), i semimanubri e tutto quanto. Se hai tutto il necessario, dovrai solo adattare il perno di sterzo (magari bastano 2 cuscinetti adatti e uno spessore), altrimenti...
| Author: | paso750 [ Mon Jan 14, 2008 9:05 am ] |
| Author: | ducapiero [ Mon Jan 14, 2008 11:06 am ] |
Thanks guys,but i noticed that Gerhard hit the problem..... to little space between fork tube and tank ......no matter it's a good reason to spend my money for a better part lamps Piero |
| Author: | paso750 [ Mon Jan 14, 2008 1:29 pm ] |
I will try my other fork one day and I also have an old dented tank to test with. The edge needs to be cut away and then rewelded. Maybe in summer ... G. |
| Author: | Desmo_Demon [ Mon Jan 14, 2008 2:04 pm ] |
| Author: | ducapiero [ Mon Jan 14, 2008 2:53 pm ] |
my problem about axle is that i have a rim 4.5 with 17mm of innner diameter but i think i can use only axle from 907 or m 900,the other are not long enough,but as you said i noticed that this type of axle are 20 mm of diameter .......i hope i don't have to machine the hole of my rim ....
| Author: | Desmo_Demon [ Mon Jan 14, 2008 4:16 pm ] |
| Author: | ducapiero [ Mon Jan 14, 2008 5:47 pm ] |
Demon the problem it's not the bearing but the rim's hole..... give me notice when you check your rim... lamps Piero |
| Author: | Desmo_Demon [ Wed Jan 16, 2008 2:25 am ] |
| Author: | Tamburinifan [ Wed Jan 16, 2008 10:41 am ] |
All early 17 wheels on 851/SS/907/888/Monster have same axles, 20mm front & 17mm rear. But locking nuts on my 907 is 24 mm & 22 on my Monster.... Think the bracket from a Monster will fit, not so sure about the caliper fitting. |
| Author: | ducapiero [ Wed Jan 16, 2008 9:59 pm ] |
thanks for the answers guys,today i find an axle from a monster 600,it is 17 mm of the diameter and 330mm of lenght,i think the sizes are ok.... what do you think?? lamps Piero |
