| new member with beat up 87 http://ducatipaso.org/forum/viewtopic.php?f=1&t=2256 |
| Author: | devo87 [ Fri Jan 25, 2008 10:41 pm ] |
| Post subject: | new member with beat up 87 |
hi jus researching madly about my poor old bike its been through the wars 1st swing arm bolt holes butchered [getting welded an machined] 2 about 15 teeth missing off 3rd gear/3 housing broken were chain mustve snapped /4 cluth pack down to steel on some/5 fairings need repair an repaint/so while im at it will do cam belts/sprokets an chain if finances allow so once i figure out how to post my pics i will put down a more detailed history look forwardto any help and friends i might meet on the way |
| Author: | Tamburinifan [ Sat Jan 26, 2008 1:11 am ] |
| Post subject: | Re: new member with beat up 87 |
We will help you. Welcome! |
| Author: | silverfox [ Mon Feb 25, 2008 10:02 pm ] |
Devo87, I am also in Christchurch, bought a wreck 5 years ago, have changed to Mukuni carbs,hone and rings,clutch,rectifier probs,rebuild heads,clutch slave sleeve/rebuild, 2 repaints etc etc etc and in the process of changing to 17" rear. I could probably give you some good info.......how to....where to go, etc Tony tony.devries@telecom.co.nz |
| Author: | Desmo_Demon [ Mon Feb 25, 2008 10:11 pm ] |
| Author: | persempre907 [ Tue Feb 26, 2008 7:15 am ] |
You'll have to work!!! Good luck! |
| Author: | paso750 [ Tue Feb 26, 2008 9:16 am ] |
welcome, I guess one of the first things you`ll want is: http://www.desmotimes.com/product70.htm I have one of those. It`s currently being powder coated. I`ll make a drawing when I get it back as I figure it`s not hard to make one yourself. Good luck with your rebuild. Upcoming frustration will be gone the first time you hear the bike and when you ride it G. PS: to post pics upload them on ie photobucket.com (you need to register but it`s for free), then when posting in the forum copy the direct link of the picture into your post after you clicked on "Img" which you`l find above your editing window. So then it is [img]direct-link-to-jpg[/img] |
| Author: | Fraser [ Wed Feb 27, 2008 6:26 am ] |
Devo87, When did you buy the Paso; it's just I remember seeing a white one advertised on TradeMe last year, that was from Christchurch, that looked like it needed a bit of help? Lots of assistance from this site, hope we can help. Fraser. |
| Author: | jcslocum [ Wed Mar 05, 2008 1:12 pm ] |
Ouch, the broken engine case is really a bad deal. It could require a complete tear down to make a repair or replace. I had the output bearing fail and chew up the case. I bought a new bottom end instead of tearing it down. We're here to help! |
