| mounting new 907 swingarm http://ducatipaso.org/forum/viewtopic.php?f=1&t=2266 |
Page 1 of 3 |
| Author: | ducapiero [ Mon Jan 28, 2008 9:08 pm ] |
| Post subject: | mounting new 907 swingarm |
Hi guys my time is come i miss only rear disc and then i'll have all the "necessaire"to mount my new swingarm with my new tyre(very-soft) Now my question is : it will be so difficult to disassembe old swingarm and mount the new one? i need special tools? all suggestions will be appreciated lamps Piero |
| Author: | paso750 [ Tue Jan 29, 2008 10:05 am ] |
| Post subject: | Re: mounting new 907 swingarm |
Hi Piero, removing the swingarm and putting the new one in doesn`t require special tools, just the usual and maybe a rubber hammer and a torque wrench. Just figure out how to make the bike stand stable when you remove wheel and swingarm. If you don`t know age and condition of the swingarm bearings you should change them, now that the swingarm is not yet in the bike. G. |
| Author: | Desmo_Demon [ Tue Jan 29, 2008 2:33 pm ] |
| Author: | ducapiero [ Tue Jan 29, 2008 5:26 pm ] |
Thanks guys...but i forget ot ask you one thing do yu now the measure of the spacers to put between swingarm and rear wheel ?? how i have to take this measurements.... P:S: today i finished to mount 4 piston brembo calipers and semi radialpump from 999....... what a a difference
| Author: | paso750 [ Tue Jan 29, 2008 7:47 pm ] |
according to the 17" conversion info (that can be found in the downloads thread) it`s 5mm thick, inner diameter 20mm, outer 35mm. G. |
| Author: | ducapiero [ Wed Jan 30, 2008 6:02 pm ] |
stange only 5mm of thickness,it seems to me strange the brake caliper support on the other side of the rim is 17,9 mm of thickness i have to investigate i 'll give you notice lamps Piero |
| Author: | paso750 [ Wed Jan 30, 2008 6:13 pm ] |
have you checked the files again ? But I noticed there`s a difference. You say your brake adapter is 17,9mm, the one of the guy describing the 17" conversion is 10mm. In that case your spacer should be even thinner |
| Author: | Desmo_Demon [ Wed Jan 30, 2008 6:25 pm ] |
| Author: | ducapiero [ Thu Jan 31, 2008 11:51 am ] |
MMMMMMMMMM i have done a wrong in measurement the caliper bracket is 29,8 mm i take this bracket from a monster 900 and it's the type with caliper positionated down.... I think it 's benn a erious problem to take right measurement for sapcers,i'm terrified to think what can be happen if i wrong ...
| Author: | paso750 [ Thu Jan 31, 2008 12:03 pm ] |
Piero, try to ask Zap. He has Supersport wheels on his bike, maybe he can tell you what brake adapter he used and what spacer. G. |
| Author: | ducapiero [ Thu Jan 31, 2008 2:05 pm ] |
Thanks G. but i mount a 907 swingarm,that is larger than stock 750,and as i see by this photo he mount the wheel with the old swingarm...... tel me if i'm in wrong lamps Piero |
| Author: | paso750 [ Thu Jan 31, 2008 2:10 pm ] |
sorry I didn`t think of that , then of course also the before mentioned spacer is probably incorrect as the 17" wheel conversion (file) was done with the original swingarm also.G. |
| Author: | Desmo_Demon [ Thu Jan 31, 2008 5:32 pm ] |
I don't have my 907 swingarm back from being welded because of some sprocket bolts that backed out, but I do have a 907 caliper bracket and a wheel with sprocket carrier from a '94 SS900 (4.5" width) if there are any measurments that I can help you with. |
| Author: | paso750 [ Thu Jan 31, 2008 7:14 pm ] |
I have a complete 907ie swingarm right at hand and could measure here. G. |
| Author: | ducapiero [ Fri Feb 01, 2008 11:05 am ] |
Thanks guys i'm waiting for your "SAINT" measurement
| Page 1 of 3 | All times are UTC |
