| Original 280 rotors on 17 " wheels? http://ducatipaso.org/forum/viewtopic.php?f=1&t=2278 |
| Author: | nilaus [ Thu Feb 07, 2008 10:26 am ] |
| Post subject: | Original 280 rotors on 17 " wheels? |
When converting to 17 “ wheels, has any one used the 280 front rotors with some kind of adapter to fit the wheels? It looks as if on this F1 there is fitted an adapter. : And if so, where do i get such a pair? Regards Klaus |
| Author: | paso750 [ Thu Feb 07, 2008 11:20 am ] |
| Post subject: | Re: Original 280 rotors on 17 " wheels? |
it`s a 750 Sport. However I doubt that there are many 17" conversions keeping the small brake discs. As it seems the adapters are part of the PVM wheels, here`s a pic I found on another german page: G. |
| Author: | Desmo_Demon [ Thu Feb 07, 2008 2:00 pm ] |
| Author: | nilaus [ Thu Feb 07, 2008 3:51 pm ] |
You are properly right. It was only because that there are no discs with the wheels that I have just purchased and the discs on my 16” are quit new. Regards Klaus |
| Author: | Desmo_Demon [ Thu Feb 07, 2008 6:53 pm ] |
| Author: | Finnpaso [ Fri Feb 08, 2008 10:06 pm ] |
Desmo Demon; I think JUST as You !!!! Why to use so awfull 2 piston calipers?
| Author: | persempre907 [ Sat Feb 09, 2008 7:28 am ] |
I changed the whole front brake system (Brembo full floating rotors, newer goldline calipers, 999's radial master cylinder and braided lines). I'm very, very happy. Ciao |
| Author: | Finnpaso [ Sat Feb 09, 2008 8:50 am ] |
I changed hole 907 system(with steel braided lines) to my 750 Paso, but still original iron rotors.. I am also very happy to it now.... I want to keep that combination also, when i swap 17" wheels and then add 320 rotors(from 92 907).
| Author: | Desmo_Demon [ Mon Feb 11, 2008 3:51 pm ] |
