| found a 16" tyre?? http://ducatipaso.org/forum/viewtopic.php?f=1&t=2300 |
| Author: | zap [ Thu Feb 21, 2008 8:46 pm ] |
| Post subject: | found a 16" tyre?? |
hi ,While i was looking for new tyres, i checked for tyres that might fit the original paso rims and i found something that might fit the rear wheel. Please correct me if i'm wrong. http://www.rodamoto.es/OnLine/IN/productoId.aspx?Id=167 And for the front, if you lift your fender a little: http://www.rodamoto.es/OnLine/IN/productoId.aspx?Id=22 If it fits, it is a very cheap and better alternative. let me know, ab.
| Author: | paso750 [ Fri Feb 22, 2008 9:14 am ] |
| Post subject: | Re: found a 16" tyre?? |
it seems to be tight to fit a 150/80-16 so I guess a 170/70-16 has the same problems. Then it`s only HR rated and a tire for tourers. I was looking into a 180/60-16 Avon, that was the only VR rated tire in that size and not made for tourers, unluckily meanwhile that model was discontinued also. G. |
