| Gear whine http://ducatipaso.org/forum/viewtopic.php?f=1&t=2319 |
| Author: | pasophist [ Tue Mar 04, 2008 9:04 pm ] |
| Post subject: | Gear whine |
'88 Paso. 45,000 miles. In third gear I get a lot of gear whine. I think it is getting worse over time. What are the options of what it can be? How serious is it likely to be? What should I do about it? Thanks SMS |
| Author: | jcslocum [ Wed Mar 05, 2008 1:27 pm ] |
| Post subject: | Re: Gear whine |
Is this at all speeds/rpm?? |
| Author: | paso750 [ Wed Mar 05, 2008 2:39 pm ] |
... or under hard acceleration combined with a power loss, then it could be a slipping clutch. Is it only in 3rd gear ? In the worst case the teeth of your gear are worn and if pieces brake off, this could lead to an engine damage sooner or later. viewtopic.php?f=3&t=2259 G. |
| Author: | pasophist [ Wed Mar 05, 2008 4:32 pm ] |
Not the clutch- at all speeds. the whine follows the rpm with pitch increasing with rpm. |
