ducatipaso.org • View topic - the engine doesnt want to start
It is currently Fri May 15, 2026 9:54 am
 Post subject: the engine doesnt want to start
PostPosted: Wed Sep 10, 2008 3:40 pm
hello there,
guys, I really need your help
some days ago my Paso started to turn the engine off when I stop at crossroads,
I had to turn the lights off and start the engine again...
but from today I have problems with starting the engine. when I turn the lights off
and push the "start" button - the engine doesnt start...
SOMETIMES it helps when I turn the key off, and turn it on... then push "the start"
and sometimes (what is really weird) I have to turn the key off, turn the wheel left (!),
turn the key on and then it works... but it happens that I have to wait some time to start
the engine... dont know why...
(strange thing with that wheel - last time, when the key was on, the fuel level gauge was
not working - but I had only to turn the wheel left, and suddenly it started showing the fuel level)
it seems that`s not problem with "start" button, but with ignition switch
as when I turn the key on, the engine and all controls do not react...
in my last topic I write about oil leaking... can it be connected?
cheers!
 Post subject: Re: the engine doesnt want to start
PostPosted: Wed Sep 10, 2008 5:09 pm
not likely that the problems are connected.
If turning the steering makes some change check all connections and connectors in the front. It might be that the fork thouches some wires and while doing this cuts a connection or creates one.
Pull the thin red wire that goes to the starter relais, Do you have 12V when you push the start button, do you have 12V at the coils ? Are all ground connections in the front ok ? (when you remove the tank you see a round black rubber "thing" and on the opposite side, on the bottom side of the frame you have one of the main ground points.)
Have you tried to remove the ignition switch and shortwire the bike ?
I always have a cable with crocodile clips with the Paso. The ignition switch also failed once and it took only a few minutes to bypass it. If it is the switch it`s not so difficult to open and clean it.
PostPosted: Wed Sep 10, 2008 5:44 pm
thanks for your answer, but let`s start from the beginning - why the engine turns off while im stopping the bike?
you know, the problem with ignition switch (and starting the bike) is ONLY after the engine suddenly turned off.
I do not have problems with starting the bike in normal situations (like starting from parking)
you see, I`m trying to stop/slow the bike, the engine turn off, I turn the key "off", and turn it "on" again - now all controls should light up and engine should start giving a sound... but i doesnt... :(
PostPosted: Wed Sep 10, 2008 6:17 pm
PostPosted: Wed Sep 10, 2008 8:02 pm
It may be that without the vibration of the bike moving, the tank is not pressing down on the earthing unit (the black 'thing' mentioned by Paso750) under the tank, causing it to break contact. The fact that you were able to get the bike started after turning the bars to the left suggests that the problem may be with the earthing unit.
Take the tank off (carefully if you've never done it before - there are are fuel and electrical lines and connections you might break if you're not careful), find the round black 'thing' that sits on the frame at the top under the front of the tank (it might even fall free when you take the tank off and might even fall between the cylinders) and see how it holds several wires earthed onto the frame, then figure out how to make the assembly more secure. I use a small rubber band.
PostPosted: Thu Sep 11, 2008 6:49 am
thanks for your help!
I`ve got more details: now it really seems that there is sth wrong with the wheel.
today morning when I turn the key on, the wheel was straight, I turn the wheel left
and then was turning it back very slowly to straight position - when it reached the straight
position the bike cut connection. but then I turn the wheel right - connection came back :)
but, when I turn the wheel rapidly - from left to right - the connections is also cut (when
the wheel reaches the straight position) but the moving is so fast that connection came back
unnoticed.
it makes sense - when I was riding there was no problem, but when I wanted to stop the bike
I was making very slow movements and the connections was cut....
anyway, with that details - is it still problem with earthing unit?
cheers!!
PostPosted: Thu Sep 11, 2008 7:15 am
:thumbup:
Yes. The earthing unit is the first thing I would check. You might be able to get the same effects by banging down or pressing down on the tank with ingition key turned to on, and you might be able to feel the bottom on the earthing unit with a finger if you put your hand under the front of the tank, in the middle, under the frame just behind the steering head. You should feel a small metal cup up under the front of the tank. Press on the cup with a finger of your left hand, and down on the tank with your right hand to make the earthing unit work.
PostPosted: Thu Sep 11, 2008 8:02 am
PostPosted: Thu Sep 11, 2008 8:22 am
The earth wires are held in place by the metal cup which is on the end of a small tube which is a friction fit into the round black rubber tank rest. The cup holds the wires up in contact with the frame behind the steering head. The small tube fits through a hole in a plate on the frame into the 'thing' which the tank is sitting on (the wires contact the bottom of the plate) so moving the tank moves the earth connection. As standard, it's a rather flimsy arrangement.
PostPosted: Thu Sep 11, 2008 10:13 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Sep 15, 2008 4:19 pm
hello there,
problem solved.
the red cable from the battery to ignition switch was damaged :)
thanks for help guys!
PostPosted: Mon Sep 15, 2008 5:22 pm
good to hear ! :thumbup:
PostPosted: Tue Oct 28, 2008 1:37 am
Had a similar problem. It was the ignition wiring shorting out. This could explain why, when you turn your bars left it runs. The left turn could be making the correct connection....repair/rewire ignition.
PostPosted: Tue Oct 28, 2008 11:03 am
Hello PASO88!!!
Where in Westchester are you and are you a member of the local club?
Jon from Dutchess County.
Users browsing this forum: No registered users and 28 guests
