| Clutch creeping? What is this? http://ducatipaso.org/forum/viewtopic.php?f=1&t=2351 |
| Author: | TyGoodrich [ Fri Mar 21, 2008 3:01 am ] |
| Post subject: | Clutch creeping? What is this? |
I just bought a 88 750 Paso from my buddy. So far, i runs pretty good. I took it for a jaunt around San Francisco, and the clutch started swelling maybe? I had the clutch handle all the way to the hand grip, and the bike started creeping forward. I also couldn't get the bike into neutral if my life depended on it. My friend said something about bleeding the clutch, and apparently this was a known problem for Paso's. Does anybody know how I fix this, or at least keep up on the problem? Thanks! New Paso Owner. |
| Author: | jcslocum [ Fri Mar 21, 2008 2:29 pm ] |
| Post subject: | Re: Clutch creeping? What is this? |
Bleeding the clutch is, in theory a simple task. The reality is, it can be a bitch!! There's 2 ways to do it: Pump and bleed or vacuum bleed. Take a look at this "pump and bleed" and see if you get it. The cutch is done in the exact same way. http://www.ducatisuite.com/brakebleeding.html With proper bleeding the clutch will be perfect. |
