| Valve clearance. http://ducatipaso.org/forum/viewtopic.php?f=1&t=2360 |
Page 1 of 2 |
| Author: | paso144 [ Thu Mar 27, 2008 9:53 pm ] |
| Post subject: | Valve clearance. |
Hello, Since my Paso has reached the 30.000 km I thought of checking the valve clearance. So I started with the standing cylinder. With the piston in top dead center I measure a clearance of 0.05 mm on the opener on the exhaust side and 0.1 mm on the closer, which is within spec. But on the intake side I don't measure a clearance at all. A 0.05 mm feeler gauge can't be put between the cup and the opener. The closer has about 0.05 clearance. Now I know that Ducati specifies the opener clearance at < 0.1 mm but I find it strange that there is no clearance at all. Has anyone of you ever encountered this? The thought of a worn out valve seat crossed my mind but then I would also have measured a lot more clearance on the closer. I guess that no clearance/play can't hurt but I like to double check. greetz Remko (Paso144) |
| Author: | Tamburinifan [ Fri Mar 28, 2008 12:33 am ] |
| Post subject: | Re: Valve clearance. |
| Author: | paso144 [ Fri Mar 28, 2008 8:15 am ] |
Hello Gert, 0,00 to 0,02 mm looks like a strange value. How are you going to measure this when the measuring tool (feeler gauge) only has a resolution of 0,05 mm. Aren't you mistaking wiht inch values? regards Remko |
| Author: | Desmo_Demon [ Fri Mar 28, 2008 10:49 am ] |
I set my openers between 0.004" and 0.006" (0.10mm and 0.15mm) I set my closers between 0.000" and 0.002" (0.00mm and 0.05mm) To get the closers right, I make sure that I can not get the 0.002" (0.05mm) feeler gauge to fit between the opening rocker and opening shim. Then, to make sure that I do not have the clearance at a negative value, I push the closing rocker down (to relieve the pressure of the rocker spring), and make sure I can rotate the closing shim with my fingers. I also will remove the belt from the cam and rotate the cam while feeling for resistance or any sign of binding. If you cannot rotate the closing shim with your fingers and feel a scraping or resistance in the cam shaft when rotating, DO NOT leave the closing shim like this, as you are binding the system. I hope this helps. |
| Author: | Tamburinifan [ Fri Mar 28, 2008 11:46 am ] |
+1 on what dd says. You should be able to turn the closing shim one half turn when spring is pressed down. |
| Author: | paso144 [ Fri Mar 28, 2008 2:04 pm ] |
Ok, So this is a lot of advice on the closer, although I don't understand the comment about a half rotation of the cup (tamburinifan?). But I'm still wondering wether a 0 clearance on the opener is a problem? And do you really think I need to adjust the clearance on the closer on the exhaust side which is currently 0.09 - 0.10 mm, because this is some work since you have to remove the opener by removing its shaft? Regards Remko |
| Author: | Skins [ Fri Mar 28, 2008 5:13 pm ] |
I'd like to add that it is very important that all measurements are made with an absolutely cold motor, one that has been allowed to cool at least overnight, otherwise you will not get correct measurements. Also, removing the rocker shaft is very easy - it takes only a few minutes to do. |
| Author: | Desmo_Demon [ Fri Mar 28, 2008 5:34 pm ] |
| Author: | Finnpaso [ Fri Mar 28, 2008 7:45 pm ] |
| Author: | paso144 [ Fri Mar 28, 2008 8:24 pm ] |
Thanks for all your reply's, To start the cup under the opener which I can't measure because of lack of thinner feeler gauges then 0.05 mm, still can be rotated fully. So I would say there is some clearance probably in the region of 0.01 to 0.02 mm. So I don't sink I have negative clearance. But can anyone exactly state wan't the present values then have to be for opening and closing clearance. regards, Remko |
| Author: | Skins [ Fri Mar 28, 2008 9:10 pm ] |
My official Ducati Workshop Manual says opening clearance 0.1mm and closing clearance 0 to 0.02mm and that's what I do. And Antti, as as ex-English language teacher, I must give you a lesson (although I do think you use the English language in a wonderful way): in English, "hardly" means "not much", as in 'I hardly speak any French, only enough to say oui and merci'; and "hard" means "strong" or "with great force" as in 'steel is hard' or 'Stoner rides his Ducati hard'. |
| Author: | Tamburinifan [ Sat Mar 29, 2008 12:16 am ] |
| Author: | Finnpaso [ Sat Mar 29, 2008 8:43 am ] |
| Author: | Skins [ Sat Mar 29, 2008 6:12 pm ] |
No problem, Antti. Your English is really very good, you make very few big mistakes, and the way you use the language has a lot of "character" - you are a real asset to this site. I had to correct you because you often talk about 'hardly' riding a Ducati, which means means riding them only a little, but it seems you do exactly the opposite - you ride them a lot, you ride them hard (like me)! All the best, mate! |
| Author: | Finnpaso [ Sat Mar 29, 2008 8:47 pm ] |
