| 650ss alazzurra (pantah motor) http://ducatipaso.org/forum/viewtopic.php?f=1&t=2361 |
| Author: | Debonair [ Fri Mar 28, 2008 1:09 am ] |
| Post subject: | 650ss alazzurra (pantah motor) |
Can anybody tell me if the 650 Alazzura pantah motor is the same as the 750 paso? May have found a parts bike but I want to make sure before I buy it! Thanks |
| Author: | jcslocum [ Sun Mar 30, 2008 11:28 am ] |
| Post subject: | Re: 650ss alazzurra (pantah motor) |
The place that really makes a difference is where the swinfarm attaches. You might want to post this to the Pantaheads list. I'd be interested in the asnswer... |
| Author: | ducinthebay [ Tue Apr 01, 2008 5:10 am ] |
When did they swap the direction of the rear head? I know the 750 F1 had the carb in the back, but I don't remember which way the Pantah motor had it. Clutch and gearbox is the same. Wheels would probably be 18" in back an maybe a 19" in front. Frame and body work are completely different. In short, not much matches up. Ducks of a different feather, if you know what I mean. Not a good donor bike for a Paso. It's its own project. Cheers. |
| Author: | Debonair [ Fri Apr 04, 2008 4:29 am ] |
Thanks for that info Ducinthebay. I will be staying away from that one.... |
| Author: | ducapaso [ Fri Apr 04, 2008 4:09 pm ] |
