| rear fork pivot oil seals http://ducatipaso.org/forum/viewtopic.php?f=1&t=2362 |
| Author: | eliatt [ Fri Mar 28, 2008 8:36 am ] |
| Post subject: | rear fork pivot oil seals |
Hi all, Can anyone supply me with the measuraments of the rear fork pivot oil seals? (i.d. should be 19 mm. as far as I know ) Local dealer do not stock them (surprise...surprise..), and since it`s my commuter, hate to get them out just to discover they cannot be found... Thanks, Eli |
| Author: | paso750 [ Fri Mar 28, 2008 12:39 pm ] |
| Post subject: | Re: rear fork pivot oil seals |
did you check the last page of the FAQs ? G. |
| Author: | eliatt [ Fri Mar 28, 2008 1:06 pm ] |
Hi G., Actually, I did look. am I missing something? or maybe I wasn`t clear eanogh: I`m talking about the chrom tube that runs through the engine, and enable swingarm movements. Sorry to trouble you. Thanks, Eli |
| Author: | jcslocum [ Sun Mar 30, 2008 11:39 am ] |
Eli, The part you are talking about is the swingarm. Yes it looks like a fork but that's on the front of the bike! The seal part number is 937831526. This is the seal for the swingarm bolt that is in the engine case. I have a set of cases here and can measure the seal later. |
| Author: | eliatt [ Sun Mar 30, 2008 6:15 pm ] |
Hi, Thanks, & sorry for the term mixup.. |
