| rear wheel bearings http://ducatipaso.org/forum/viewtopic.php?f=1&t=2387 |
| Author: | sprintex [ Fri Apr 11, 2008 7:49 pm ] |
| Post subject: | rear wheel bearings |
While giving the Paso a look over I found that there is side play in the rear wheel. Before I pull off the wheel is there anything I should know about replacing the rear wheel bearings? Is it just a matter on knocking them out like I do on a Guzzi? Then tapping back in? On the plus side, the bike started up and ran nice on the short ride I took. Did not go to far do to the loss rear wheel. Also can the front brake rotors be grounded down? When braking hard I get a lot of vibration. |
| Author: | sprintex [ Sat Apr 12, 2008 12:44 am ] |
| Post subject: | Re: rear wheel bearings |
Well I answered my own question, they tap out, no problem. Looks like the sprocket bearing is also shot.
| Author: | jcslocum [ Sat Apr 12, 2008 1:03 am ] |
We didn't even get a chance to jump in here!! Glad you got it figured. |
| Author: | Desmo_Demon [ Sat Apr 12, 2008 6:04 pm ] |
| Author: | Skins [ Sun Apr 13, 2008 1:47 am ] |
The original front brake rotors certainly can be turned down. I had mine done about a year ago. |
| Author: | sprintex [ Sun Apr 13, 2008 12:35 pm ] |
I order the wheel bearings from a bearing dealer in Hartford. $28 each for the RFKs which was the only brand that had the right size. Ouch, I paid $8 for per bearing for the LeMans. I'll check on having the disc turned. I'm thinking of selling the Paso now that its all sorted. I always end up doing this. I'm thinking of getting back to owning one bike. Maybe a Buell Uly if I can find a used one in the locally . |
| Author: | ducinthebay [ Mon Apr 14, 2008 4:55 am ] |
Don't sell your Paso. You will regret it. I had a 98 ST2 for 5 years and had sorted out all of its little ills, then sold it to get an ST4s. I still can't ride the new bike as well as the old bike, and I'm constantly sorting out all those things I did over the past 5 years on the older bike. Too much time wrenching, and not enough time riding. Now don't get me wrong, I love to wrench as well as ride, and if I didn't, I would just buy a Honda and accept the ride for what it was. But that's just not the way of this tribe. But there is a balance, and I have once again stepped onto the wrenching side of things. Bad timing with the weather so lovely lately. I'm just riding a half finished project bike all the time. Cheers, |
