| Clutch Plates http://ducatipaso.org/forum/viewtopic.php?f=1&t=2465 |
| Author: | bucbean [ Fri May 09, 2008 9:47 am ] |
| Post subject: | Clutch Plates |
5/9/08 I have a '90 750 Sport. I gather that all 5 speed clutch packs from this era are the same. Could someone give me order and orientation of assembly for plates? I have a parts manual PDF that shows an order....but It looks like there are two different steel plates....and I believe one if not both are convex? Anyway....if it might be easier to draw it and fax it to me...I would really appreciate the help. I had a slipping clutch....I installed the new clutch pack in the correct order (I thought...though I had no instructions...and the shop manual stinks). Now the clutch "grabs"..and chatters. My fax number is 603 415 2489. Thanks a MILLION. Jeff |
| Author: | desmodave [ Mon May 19, 2008 4:25 pm ] |
| Post subject: | Re: Clutch Plates |
generally a clutch has to disengage after a year and a half off my paso cause of allsorts of silly reasons try taking out one at a time till you get the right width. i have a pack i blew up and finally got it right through the m.o.t so ill get some new plates now i know the width. make sure the cut outs are 1/4 clocklike it balances the clutch ok. |
| Author: | Finnpaso [ Mon May 19, 2008 5:15 pm ] |
| Author: | paso750 [ Mon May 19, 2008 5:52 pm ] |
| Author: | Finnpaso [ Mon May 19, 2008 7:09 pm ] |
ok, but main point wasnt that... There is huge number of allking shortened words, things, etc, so its sometimes horrible to think, what they maybe can mean.... Maybe time to make new topic to all such letter combinations in aplhabetical order, that everybody can understand.....
