| speedo drive http://ducatipaso.org/forum/viewtopic.php?f=1&t=2488 |
Page 1 of 2 |
| Author: | paso750 [ Fri May 16, 2008 6:24 pm ] |
| Post subject: | speedo drive |
According to my dealer this is probably one of the next parts that will become rare. Putting the front end back together again today I noticed the first time that the speedo drive has a grease nipple. So every couple of years one should give it some grease if it doesn`t turn freely like mine did. The internal parts are probably plastic so it`s better not to use oil. (just a guess, could be brass or some other material also) G. |
| Author: | ducapaso [ Sun May 18, 2008 8:30 am ] |
| Post subject: | Re: speedo drive |
Mine has gone some time ago (the brass nipple separed from the alu body and the inner gear lost Still unable to replace it. You must look at the ratio punched in the body to be sure you found an oem part: furthermore you can meet an counterclockwise gear and you might see the speedo hand go under zero level!!! Test it moving the wheel with your hand before riding it! |
| Author: | paso750 [ Sun May 18, 2008 9:55 am ] |
ratio is 21/12 Why are you unable to replace it ? Ducati still has it and Stein-Dinse is selling it for around €40,-. This one looks like it but it doesn`t mention axle diameter, width or ratio: http://cgi.ebay.de/aprilia-rs-tachoantr ... dZViewItem G. |
| Author: | Finnpaso [ Sun May 18, 2008 11:49 am ] |
Can that part find from Aprilia (125cc) spare part catalogues? Just quessing now.......
| Author: | paso750 [ Sun May 18, 2008 12:42 pm ] |
according to the auction: aprilia RS 125 1996-2005 RS 250 1995-1997 |
| Author: | Finnpaso [ Sun May 18, 2008 1:08 pm ] |
Ok, thanks! |
| Author: | paso750 [ Mon May 19, 2008 2:08 pm ] |
a seller on ebay told me width is 15mm, ratio is not mentined on the part and axle diameter is 20mm. The Paso axle is 17mm. |
| Author: | Finnpaso [ Mon May 19, 2008 2:35 pm ] |
then have to make spacer to fit it to Paso.... What is wheel size in Aprilia? That can lead to ratio, but i think, its NOT 16", as in Paso
| Author: | paso750 [ Mon May 19, 2008 3:46 pm ] |
yes, 17" |
| Author: | Finnpaso [ Mon May 19, 2008 4:09 pm ] |
So right ratio for 907IE...... But propably again problems with axle diameter... Anyway, spacer is not so difficult to do with lathe. |
| Author: | ducapaso [ Tue May 20, 2008 5:44 am ] |
| Author: | paso750 [ Tue May 20, 2008 4:48 pm ] |
have you done it before ? However, that only makes sense if your original housing is broken, not if something inside is defect. I was discussing with Antti before, what washers/spacers are on the left and right side of the front wheel ? I found only one. According to the parts catalogue there`s one that comes with the speedometer drive. How does that one look like? Anyone have pictures, what are the measurements ? G. |
| Author: | ducapaso [ Tue May 20, 2008 5:00 pm ] |
| Author: | Desmo_Demon [ Thu Jun 05, 2008 10:23 am ] |
Lat week, I just had the tab that fits into the front wheel break on my Paso. I had a spare speedometer drive unit, so I installed that one. Does anyone know if I can buy just the back plate with that tab? That piece is easily removable with a simple retaining ring that you can pull out of the unit with your fingers. |
| Author: | cagiva905 [ Mon Jun 09, 2008 7:15 pm ] |
I had a similar problem on the speedo drive of my 350 Elefant a few years back (similar drive). I was able to weld the notch back on the ring, and thoroughly cleaned and greased the inner parts. I was not able to disassemble it completeley but the ring came off. I put everyting back together but also, to prevent twisting of the ring, I put some strips of neoprane tape on the ring that now is pushed flush with the gear by the wheel hub. No problems so far ![]() Michiel http://www.elefant.nl http://www.endless-horizons.net |
