| clutch slave seal fitment ? http://ducatipaso.org/forum/viewtopic.php?f=1&t=2499 |
| Author: | cat980 [ Tue May 20, 2008 7:39 pm ] |
| Post subject: | clutch slave seal fitment ? |
hi would this fit my 88 750 sport / paso? http://motographix.co.uk/html/other_stuff.html cheers. |
| Author: | paso750 [ Wed May 21, 2008 9:42 am ] |
| Post subject: | Re: clutch slave seal fitment ? |
As the Paso and Sport have an O-ring it could be that the piston has a round shaped groove. (don`t remember) I`m using a clutch piston of a 900SS/749/996B/900M and this one has a V-type seal and a square groove. Better check if you remove your piston. I don`t think it`s ideal to put a seal that`s made for a square groove in a round shaped groove, if that is the case. However, it was done before. Check the FAQs. G |
| Author: | cat980 [ Wed May 21, 2008 5:48 pm ] |
ideal,many thx paso |
| Author: | cat980 [ Wed May 21, 2008 6:02 pm ] |
have just stripped it out and have the following. |
| Author: | paso750 [ Thu May 22, 2008 8:48 am ] |
looks good. If the outer diameter is 26mm the Xring of these models should fit |
| Author: | cat980 [ Thu May 22, 2008 4:40 pm ] |
nice one,thanks m8. |
| Author: | cat980 [ Thu May 29, 2008 9:09 pm ] |
just an update from that link in my original post.it fits my piston and works a treat on my 750 sport...phew. http://cgi.ebay.co.uk/Ducati-Clutch-Sla ... m153.l1262
