| front wheel spacer issue http://ducatipaso.org/forum/viewtopic.php?f=1&t=2505 |
| Author: | paso750 [ Wed May 21, 2008 6:20 pm ] |
| Post subject: | front wheel spacer issue |
Hi, as I wrote in another thread I have a problem assembling the front end of my bike. According to the parts catalogue there are 2 spacers at the front wheel. One on the right side and one at the speedometer drive. What outer diameter and exact width are these ? If anyone has the front wheel removed, could you check ? thx, G. |
| Author: | Desmo_Demon [ Thu May 22, 2008 1:36 am ] |
| Post subject: | Re: front wheel spacer issue |
Here are the measurements I got with a metric ruler... 17.5mm ID x 26mm OD x 2mm with a micrometer, I got this... 0.678" ID x 1.012" OD x 0.077" thickness Both of my bikes only have one spacer on the right side. Neither has one on the speedo side. |
| Author: | paso750 [ Thu May 22, 2008 8:52 am ] |
thanks very much. Strange that the manual shows one per side. I saw an old 851 yesterday and that one had a spacer per side also. I still wonder why there is a spacer on the right side as they only had to make the axle some milimeters longer. Only guess I have is that the threaded part shouldn`t stick out on the left fork side. G. |
| Author: | paso750 [ Thu May 22, 2008 5:32 pm ] |
Terry, did you actually remove the axle to check ? Just wondering if the "spacer" on the speedometer drive side could be a shim which is hard to see with the wheel still in place. |
| Author: | Desmo_Demon [ Fri May 23, 2008 10:02 am ] |
