| Valve adjust / Check on an early Paso http://ducatipaso.org/forum/viewtopic.php?f=1&t=2509 |
| Author: | Pasodoble [ Sun May 25, 2008 5:47 am ] |
| Post subject: | Valve adjust / Check on an early Paso |
Does anyone know where I can find a good description of how to adjust valves on the early Paso 750 that does not have the removable clips on the rocker arm shafts? I was told the pasos with the yellow rocker-box caps have the clips and earlier "plain capped" Pasos don't Are clips easy to retrofit? Thanks Roger. |
| Author: | Fraser [ Mon May 26, 2008 8:41 am ] |
| Post subject: | Re: Valve adjust / Check on an early Paso |
Roger, Here you go http://www.ducatisuite.com/valves.html A nice step by step description. Fraser. |
| Author: | paso750 [ Mon May 26, 2008 8:47 am ] |
have you checked the workshop manual ? I had the rocker arms on my Paso changed to the newer type with clips. I got some used rocker arms from a Supersport. The job was done by my dealer but I don`t think it`s so difficult to change them (just be sure that te valve doesn`t drop in when you remove the rocker arm). G. |
| Author: | Pasodoble [ Tue May 27, 2008 5:00 am ] |
I'm pleased to hear it's possible to retrofit rocker arms with clips. When you say yours were from an SS, can you be more specific?? Roger. |
| Author: | paso750 [ Tue May 27, 2008 7:29 am ] |
Roger, it has been a long time ago. The parts came from a 750 Supersport (I guess 91-97). I wouldn`t wonder if the rocker arms were the same on all 2 valve Ducs, at least all 750s (after 1990/91). The rocker arm axles don`t need to be changed. |
