| Fork seals http://ducatipaso.org/forum/viewtopic.php?f=1&t=2580 |
| Author: | silverfox [ Thu Jul 03, 2008 4:54 am ] |
| Post subject: | Fork seals |
Anyone replaced fork seals ? I was wondering how to get the old ones out. Obviously the dust seal lifts off and there is a clip on top of the oil seal that will have to be removed but what is the best way to get the old seal out?. And the other thing - what air pressure should be in the forks? Cheers Tony |
| Author: | gail [ Thu Jul 03, 2008 5:35 am ] |
| Post subject: | Re: Fork seals |
Hi, No air in the forks, I've been told by others on these forums, the valves can be used to bleed air out of forks. To get seals out use flat bladed long screwdriver, go under the seal lip and lever them out . I have found that a quick bang on the end of the screwdriver usually flips them out. .You can use a rag or small piece of timber to protect fork leg rim. Hope you have some success .., Cheers .......Marty |
| Author: | ducapaso [ Thu Jul 03, 2008 5:37 am ] |
just one tip: before starting to open forks, be sure to be a skilled clockmaker! Seals are not a standard measure and (in Italy!) they are available in the factory The workshop manual is available in the download secion of the site. Hava a nice work and |
| Author: | paso750 [ Thu Jul 03, 2008 9:13 am ] |
