ducatipaso.org • View topic - Rear suspension
It is currently Sun Jun 21, 2026 2:26 pm
 Post subject: Rear suspension
PostPosted: Tue Aug 26, 2008 11:47 pm
Hi folks, John:
I just insured my 750 Paso for another season after riding my SS for most of the summer.
The rear end is sproingy. When I sit on it, it seems to settle more than it should, and when I jump around on it in the garage, the rear is soft and springy..sproingy. I took it around the block and the rear seems to squirm when accellerating out of turns.
So- The Marzocchi unit has a plastic nut on the side at the bottom. Its not quite as it should be- I think the insert is missing. I can take off the nut and there is a inner fitting that can be screwed in all the way (done). That should firm up whatever that is (compression?) The remote reservoir was set at about 2. I turned it up and there was no force until about 5, then it was harder to turn. I turned it up to 9 of ten and it didnt seem to change anything. The large pair of locking nut adjusters on the top of the shock appear to be threaded about 3/4 of an inch from the top of the threads.
What can somone tell me about how to firm up myrear end? No stairmaster jokes please!
smseigel@shaw.ca
 Post subject: Re: Rear suspension
PostPosted: Wed Aug 27, 2008 2:50 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Aug 28, 2008 3:38 am
The remote reservoir controls the compression damping, and the plastic nut that is missing is for adjusting the rebound damping.
If the setting on the remote reservoir is above "2", and the compression isn't rock hard, then there is a problem.
You can adjust the spring preload by moving the threaded collars at the top of the spring, but if the screw that controls the rebound damping is turned all of the way in (with little or no apparent effect), then all you will have is a higher-riding, springy rear end.
It sounds like you need a re-build, or a new shock!
Users browsing this forum: No registered users and 32 guests
