ducatipaso.org • View topic - Got the bike started - really, really didn't want
It is currently Wed Dec 10, 2025 1:21 am
 Post subject: Got the bike started - really, really didn't want
PostPosted: Sun Aug 03, 2008 3:33 pm
to start, and then only when I made the spark to the top angled cylinder intermittent for a few minutes. Cylinder might have been carboned up or something, or flooded, don't know. After I had it running for a few though I could put the plug wire all the way onto the plug and it seemed fine.
Choke seems to be fine.
Let's see... Not sure the system is charging yet.
Ok, so, step one, find out if bike will even start has been done.
Oh, I have two sets of wheels now, stock and mags, original owner found some bits.
Obviously the bike has not been running for a while, fuel (gas pump) lamp is on and won't go off, since there is a gallon plus in the tank I don't know what that's about.
Idle seems high sometimes, engine could run smoother maybe, but note I've never seen a Duc run before, so I have no baseline. Anyone in Indiana that knows these bikes outside the dealership???
 Post subject: Re: Got the bike started - really, really didn't want
PostPosted: Sun Aug 03, 2008 10:27 pm
It's not a good idea to run the motor with a plug lead disconnected, or, if it is disconnected, without it being earthed - doing so can damage an ignition control unit.
Sounds like the fuel warning light is stuck on because the sensor mechanism in the tank has had no exercise. It is easy to remove and work on. You may have to replace the float if it's leaking. By adjusting the angle of the float on it's arm, the gauge can be made to read accurately. That can take an hour or two of experimentation, but it's worth it.
PostPosted: Sun Aug 03, 2008 11:53 pm
Ya, in regard to pulling the plug wires, the Bevelhead group told me the same thing.
Grrrr.
"The tires are brand new (really), and I came home tonight after letting the bike sit cold for six hours and it started right off.
The electronics die if you pull the plug wires? Yuck. Have to remember that. That's stupid, it's a hundred year old diagnostic procedure. Meh. Silly transistorized ignition.
Gotta change the oil tomorrow.
On Sun, Aug 3, 2008 at 6:30 PM, Steve Craven <> wrote:
Best way to kill your Paso ignition is pull plug wires,don't do it. Or you will have an expensive piece of furniture.
There is a growing list of Paso owners looking for a replacement Digiplex.
As the bike does not have a reserve tap the low fuel light should come on with 5lts remaining,.
Take the fuel cap off and lift the fuel gauge float to see if light goes out.
And vintage bikes usually comes with acetylene lighting.
Idle should be 1100/1200 rpm have you balanced carbs, if it has dual 36s follow same procedure as for bevel. A bit more difficult as the tank needs to be in place.
There is a Paso group on yahoo that should be able to answer all your questions.
Because your going to be needing tyres."
PostPosted: Sun Aug 03, 2008 11:54 pm
PS - Are replacement electronics boxes available if the ignition system (Digiplex?) dies?
PostPosted: Mon Aug 04, 2008 1:56 am
One of the ignition boxes I'm using comes from a 900ss, I believe. It's a second-hand unit I got from the parts guy at my local Ducati dealer a few years ago. It was priced at NZD100, but I swapped some artwork for it.
PostPosted: Mon Aug 04, 2008 5:49 am
PostPosted: Mon Aug 04, 2008 8:36 am
There were also 750 Pasos with Digiplex ignition. guess you better ask the 906 guys then.
If you have the Kokusan ignition that is used on most Supersport, Monsters, Cagiva Elefant etc the number on the modules is BB1105. These are sold quite often on ebay.
PostPosted: Tue Aug 05, 2008 5:53 am
PostPosted: Tue Aug 05, 2008 1:10 pm
