| Cheap & good replacement for Kokusan! http://ducatipaso.org/forum/viewtopic.php?f=1&t=2658 |
| Author: | Tamburinifan [ Mon Aug 11, 2008 3:06 pm ] |
| Post subject: | Cheap & good replacement for Kokusan! |
My friend found this: http://www.ignitech.cz/english/aindex.htm , go to Products, thenTCI-P4. You can download both software & manual f free. Works w W95 on. Replaces both boxes, cost 127 Eu. One Kokusan costs like over 300 new! Bolt-on, comes w Ducati ignition map that is good f most not so modified engines. I`ve had it on my M900 f 2 years, he has it on his Paso 750. More info: http://www.moto-one.com.au/performance/ ... ition.html http://www.ducatimonster.org/forums/tec ... rbies.html |
| Author: | Tamburinifan [ Wed Aug 20, 2008 12:21 am ] |
| Post subject: | Re: Cheap & good replacement for Kokusan! |
69 read it and no questions?!? I must have been crystal clear then....
| Author: | Skins [ Wed Aug 20, 2008 5:20 am ] |
Well done, Gert! |
| Author: | paso750 [ Wed Aug 20, 2008 8:35 am ] |
I only know of a guy in a Cagiva Elefant forum who used this. You really can set up about everything, but that also makes it complicated and easy to make mistakes if you don`t exactly know what you`re doing. G. |
| Author: | Tamburinifan [ Wed Aug 20, 2008 9:19 am ] |
Not complicated! Switch to module in one minute, load default Ducati Kokusan map from PC - Done! Start & go. It`s really that simple. Default has worked fine on several M900, a 900SS, a Bimota DB2 & a Paso 750. Other noticeable stuff: Instant start. Engine feels like it has gotten a huge vitamin shoot. Snakebite throttleresponse, as good or better as a well tuned ie bike. So torquey in 5/6th gear. Lurking in 6th at 60mph, then passing is a breeze & most addictive. Very smooth low revs/small throttle openings. Responds from 2k in 4th w/o rattling to pieces. Less aggressive advance in this RPM range and you`ll get this overall smoothness. Aggresive sound! Sounds like something is happening down there... Also works in f e Pantahs etc w Bosch ignition & most w ign w pickups at flywheel. I have no economic interest in Ignitech, just like this little device...
