| DUCATI PASO 750 & 906 NEW RUBBER FAIRING NUTS http://ducatipaso.org/forum/viewtopic.php?f=1&t=2668 |
| Author: | 20YearOwner [ Tue Aug 19, 2008 1:02 am ] |
| Post subject: | DUCATI PASO 750 & 906 NEW RUBBER FAIRING NUTS |
I have extra fairing nuts if you need them. I can post to USA only. $2ea. DUCATI 750 & 906 PASO New Replacement Rubber Nuts. Replacement rubber with brass inserts to fit the bodywork, fairing upper & lowers, side covers and turn signals PASO models 6MM. |
| Author: | paso_rosso [ Sat Aug 23, 2008 11:07 pm ] |
| Post subject: | Re: DUCATI PASO 750 & 906 NEW RUBBER FAIRING NUTS |
PM sent! i could use a few!! |
| Author: | Horse [ Thu Mar 05, 2009 1:03 am ] |
You have any left? If so please PM me. Horse. |
| Author: | samandkimberly [ Thu Mar 05, 2009 2:33 am ] |
| Author: | Desmo_Demon [ Thu Mar 05, 2009 10:41 pm ] |
| Author: | higgy [ Fri Mar 06, 2009 12:15 am ] |
M6 wellnuts are not hard to find,Home depot has them as well as many industrial supply houses .70US is not a bad price |
| Author: | ducapaso [ Sat May 02, 2009 9:25 am ] |
Yellow bolts are also available in Ducati: here's the one for the ST2 front mudguard: Sorry for my dirty fingers!!!
| Author: | joelbb115 [ Sun Nov 15, 2009 2:23 pm ] |
After finding the 6MM well nuts on-line for $0.70, with a shipping/handling of $7.00, that was the best deal I could find, but the shipping charges killed it (only needed 6 of them). I did find them at Lowe's in the hardware section, pretty cool as I had called nut and bolt specialty places, and hardware stores and neither had them. They were $0.92 each, and worked perfectly but if you need more than five, you may have to visit multiple Lowe's because each store will only stock five of them. |
| Author: | higgy [ Sun Nov 15, 2009 3:17 pm ] |
In the states you can find them at MSC or McMaster Carr and many Ducati aftermarket sources as well. |
| Author: | cellardoor [ Wed May 18, 2011 2:57 pm ] |
Wow thank you! I have been looking for wellnuts for a while, Lowe's saved me from buying a complete and overpriced set of fairing bolts! this would be a good one for the tech faqs... |
| Author: | persempre907 [ Thu May 26, 2011 7:51 pm ] |
http://cgi.ebay.com/ebaymotors/25-M6-1- ... ccessories ...and a good source for some black anodized M6 bolts? Ciao |
| Author: | ducapaso [ Wed Jun 01, 2011 10:12 pm ] |
Francesco, Any suggestion for Ebay Italy?
| Author: | ducapaso [ Thu Jun 02, 2011 7:12 am ] |
Here it is! I've been lucky in finding, in the next days I'll tell you the price they asked me |
| Author: | higgy [ Thu Jun 02, 2011 10:53 am ] |
Ah !!! The very special MV wellnuts |
| Author: | 20YearOwner [ Tue Dec 11, 2012 9:07 pm ] |
Update on well nuts: I found a source for an auto well nut that fits the Paso. Made by Au-ve-co Products they are located in Cold Springs KY, 41076 USA Well Nuts, Box of "50", Part #13003, Size M6-1.0 https://www.auveco.com On the website search for part number 13003. |
