| What doesn't look stock on this 750 http://ducatipaso.org/forum/viewtopic.php?f=1&t=2677 |
Page 1 of 2 |
| Author: | Dana [ Fri Aug 22, 2008 1:10 am ] |
| Post subject: | What doesn't look stock on this 750 |
and if it isn't stock, where does it look like (what type of bike) is it from? Wheels, rear brake lever mount, shift lever mount, etc. http://www.flickr.com/photos/angrytoyro ... 783204948/ |
| Author: | Desmo_Demon [ Fri Aug 22, 2008 11:50 am ] |
| Post subject: | Re: What doesn't look stock on this 750 |
| Author: | paso750 [ Fri Aug 22, 2008 12:20 pm ] |
- custom footpeg mounting brackets, footpegs and pedals - Tecnomagnesio wheels (aftermarket) - floating front brake discs (original size 280mm, probably Brembo) on adapters - original rear brake disc on adapter - black 4 piston Brembo calipers on the front (from Ducati 851 I think) - caliper adapters - steel braided brake lines and clutch line - seat has new cover (original isn`t stitched) - passenger grab handle was cut off - Conti 2in1 exhaust - vented clutch cover - carbs & air filters - oil check window from newer Duc types (probably that engine cover was changed) - oil cooler lines were wrapped with tape (probably they have cracks) - rubber tube on brake lever ![]() - front sprocket cover - numerous bolts could be stainless steels as they look quite shiny - the hole of the steering halves was machined bigger as otherwise it`s not possible that the fork tubes stick out on top - Euro talllight (are the oil coolers original ? the top and bottom part looks a little bit different compared to my own.) G. |
| Author: | Desmo_Demon [ Fri Aug 22, 2008 1:27 pm ] |
| Author: | Dana [ Fri Aug 22, 2008 4:34 pm ] |
| Author: | paso750 [ Fri Aug 22, 2008 6:33 pm ] |
he he and the link was posted in the other thread before
| Author: | Finnpaso [ Sun Aug 24, 2008 3:38 pm ] |
..btw, seems, that Gerhard have again too much freetime !!!!
| Author: | paso750 [ Sun Aug 24, 2008 6:36 pm ] |
no. Actually it is that I already had every single bolt of my bike in my hands (really! It was taken apart to the very last bit and put back together) and therefore I notice changes quite fast.
| Author: | paso_rosso [ Mon Aug 25, 2008 3:01 pm ] |
also looks like an all new custom wiring harness. very clean, btw. i cannot tell what kind of rectifier is in there because of glare from the flash. |
| Author: | Johnnie [ Sat Aug 30, 2008 6:09 pm ] |
I had a set of "rear sets" back in the 80's on my 82 gpz 550 and I would be 20 bucks that those are made by the same company. I think the name of the company was something like Tarrozi (my best guess with my memory being what it is) John |
| Author: | ducinthebay [ Sun Aug 31, 2008 4:08 am ] |
- Gia Ca Moto 2 into 1 exhaust. Loud, but very effective. - Hung on a very slick custom hanger. - Vented clutch cover Nice bike. Lots of cool modifications, and they look like they were all done very nicely. All top drawer stuff, and much of it difficult to replace. I would have to agree that a machinist owned that bike at some point, or the owner had a good machinist friend. Cheers, |
| Author: | DesmoDog [ Fri Sep 05, 2008 8:14 pm ] |
| Author: | ducapaso [ Sat Sep 06, 2008 9:06 am ] |
| Author: | Finnpaso [ Sat Sep 06, 2008 4:31 pm ] |
| Author: | ducapaso [ Sat Sep 06, 2008 5:06 pm ] |
