| oil leaking http://ducatipaso.org/forum/viewtopic.php?f=1&t=2707 |
| Author: | hellogrish [ Thu Sep 04, 2008 2:20 pm ] |
| Post subject: | oil leaking |
hello my Paso friends ![]() yesterday I noticed some oil on the ground under the bike, in the picture you can see place from where oil is dropping. what can be wrong? |
| Author: | paso750 [ Thu Sep 04, 2008 4:34 pm ] |
| Post subject: | Re: oil leaking |
just guessing, could come from the front sprocket shaft or crankcase breather maybe. Clean those areas and after a short time you should see were the oil comes from. G. |
| Author: | jcslocum [ Thu Sep 04, 2008 7:31 pm ] |
Swing arm pivot?? |
| Author: | Fraser [ Fri Sep 05, 2008 5:48 am ] |
A favorite leak place is at the rear of the motor where the neutral indicator switch is buried. Really hard to get to and the leaking oil spreads all over making identification difficult. Cheers, Fraser. |
| Author: | jcslocum [ Fri Sep 05, 2008 10:53 am ] |
BTW, how did you get that picture with your bike underwater?? :-) |
| Author: | hellogrish [ Fri Sep 05, 2008 1:00 pm ] |
thanks, I cleaned that area and will see where oil appear btw, for last 3 day there is a problem when bike is working on low RPM. the engine is choking and it sometimes turn off. it happens when I stop the bike at crossroads. is it problem with clutch? I rarely get the gear into "neutral" (I always hold the clutch when I have to stop for a little while) cheers! ps. I used my mobile phone
| Author: | Desmo_Demon [ Fri Sep 05, 2008 1:40 pm ] |
| Author: | hellogrish [ Fri Sep 05, 2008 2:46 pm ] |
waterproof? no, just simple k800i
| Author: | Finnpaso [ Fri Sep 05, 2008 6:28 pm ] |
Wondering now, that in Poland there is ONLY SOME LAKES to get such foto! GONGRATULATIONS! Ok, i was ONLY JOKING now! Clean that area well and look it closely after some times to see, what is just leaking point! |
| Author: | hellogrish [ Sat Sep 06, 2008 7:53 am ] |
guys, congratulation with your imagination ![]() anyway, any reason that my Paso started choking for last 3 days?
| Author: | JWilliam [ Sat Sep 06, 2008 11:04 am ] |
How much oil? What colour? If it is jet black droplets then it is probably from a freshly oiled chain but if it is a light brown pool then it is from the engine. I get oil dropped from the left hand centre-stand boss but it is from the chain. |
| Author: | hellogrish [ Sat Sep 06, 2008 6:46 pm ] |
definetely not much oil, and it`s also dropping from left hand centre-stand, but I cannot say whats the original place for that oil, maybe it`s from the chain as you said... truly say maybe I put too much oil? as I wrote in my previous topic, my oil window is milky and I cannot see the oil level, but recently I met with one Paso owner (luckily there is one more in my city ) - and we checked the level by putiing a metal stick into the oil container and it (aproximetely) showed that the level is definitely above the "max"...(I`ve done apr. 600km so far, with 4,5l of oil) guys, question about electric pump - I`ve got sth similar to knob marked with "1,2,3,4,5", what`s that? cheers! |
| Author: | Skins [ Thu Sep 11, 2008 6:33 pm ] |
Surely you have not had to replace 4.5 litres of oil in 600 km? I can't help you with the fuel pump question - I've had no experience with them. |
| Author: | jcslocum [ Fri Sep 12, 2008 1:17 am ] |
| Author: | streetsurfer [ Fri Sep 12, 2008 4:50 am ] |
If it doesn't turn out to be the neutral switch, check the spark plug side of the verticle cylinder head. Just to the right of the plug cutout in the second fin is a small set screw which plugs a cross drilled hole - part of how an oil galley is machined into the head. Mine started leaking there and that oil also made it's way down to dripping from the stand or there about. If yours is leaking there, you should be able to seal it with some black silicone after a thorough cleaning. I was advised by my shop that this was preferable over trying to tighten or remove and reseal the screw, because they typically wont budge. |
