| number of chain links ? http://ducatipaso.org/forum/viewtopic.php?f=1&t=2708 |
| Author: | paso750 [ Sat Sep 06, 2008 7:57 am ] |
| Post subject: | number of chain links ? |
Hi, I recently looked through a fitting chart from REGINA chains and got confused. It says: 750 Paso 87 15-38-106 (530) 750 Paso 88-90 15-38-110 (520) 906 Paso 89 15-40-108 (520) 906 Paso 90-93 15-38-106 (520) 907i.e. 90-91 15-40-108 (520) 907i.e. 92 15-40-108 (520) but with a different order number Now I guess there must be some things wrong here. I can understand that with a 40 tooth sprocket a chain is used that is 2 links longer, but I`m wondering that the 907ie uses the same chain length as a 906 although it has a longer swingarm and I also think the data regarding the P750 is mixed up. What`s the correct chain length for a P750 (520 chain) and a 907ie ? G. |
| Author: | Finnpaso [ Sat Sep 06, 2008 4:24 pm ] |
| Post subject: | Re: number of chain links ? |
I never look so closely those tables, cause there are near allways mistakes in them. I use normally much bigger in rear in my 907, so allways, when need new chain, i count, how long chain i have and i check, in what position is that adjustment in swingarm.... "its in brains, not in tables" btw, if u need to know my combination, i count and tell it to You.... |
| Author: | paso750 [ Sat Sep 06, 2008 4:55 pm ] |
I do still have the old chain of my bike so I can check that myself, but could you check the length of the 907ie chain ? Thx. G. |
| Author: | Finnpaso [ Sat Sep 06, 2008 6:20 pm ] |
Just from sauna, so very tired after , but tomorrow i let u know my sprockets/chain lenght.... But i use big rear sprocket in my 907!!!! I dont need top speed, but i want hard acceleration and good gearbox ratios in twisty roads... |
| Author: | Finnpaso [ Sun Sep 07, 2008 3:21 pm ] |
I use this combo in my 907IE: Front: 15 (original) Rear: 46 (!!!) Chain: 112 links And adjusting in swingarm is in "quite front position", so there is free play still alot for tighten chain, when it gets older. |
