ducatipaso.org • View topic - tyre pressures
It is currently Wed May 13, 2026 9:03 pm
 Post subject: tyre pressures
PostPosted: Mon Sep 22, 2008 11:43 am
what are the correct pressures in p.s.i for the michelins ive seen 33 and 38 somewhere but are these for the pirellis?
 Post subject: Re: tyre pressures
PostPosted: Tue Sep 23, 2008 8:56 am
Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi.
http://two-wheels.michelin.com/2w/front ... 4a424b424a
:thumbup:
PostPosted: Tue Sep 23, 2008 11:35 am
I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds).
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Sep 23, 2008 2:35 pm
PostPosted: Tue Sep 23, 2008 2:37 pm
