| parts again! http://ducatipaso.org/forum/viewtopic.php?f=1&t=2741 |
| Author: | desmodave [ Mon Sep 22, 2008 11:26 am ] |
| Post subject: | parts again! |
parts again! does any one know if the ss rear master cylinder is same as 750 paso? and also speedo cable/ desmodave |
| Author: | paso750 [ Mon Sep 22, 2008 1:46 pm ] |
| Post subject: | Re: parts again! |
No it`s not. The mounting hole distance is 40mm instead of 50mm but maybe an adapter plate can be made ... If I remember well the speedo cables is too short. I had 2, not sure if from Supersport or Monster and both didn`t fit. G. |
| Author: | desmodave [ Mon Sep 22, 2008 2:44 pm ] |
ta for your quick reply g. |
| Author: | redmidget [ Wed Oct 01, 2008 8:59 pm ] |
Replacement speedo cables can be ordered from . Less than £15 and very quick service. I replaced my rear cylinder with this one but you do need to make up a plate to cater for the 40mm spaced holes. |
| Author: | paso750 [ Thu Oct 02, 2008 8:01 am ] |
do you have a picture or drawing of the plate ? G. |
| Author: | redmidget [ Fri Oct 03, 2008 5:02 pm ] |
There are 2 photos and a diagram attached. It's difficult to get an angle for a clear photo but you can get the idea. Three holes in a plate; bottom cylinder mounting bolt goes through lower hanger hole, hole 1 in plate and lower cylinder mounting hole top cylinder mount is secured with countersunk bolt through hole 2 in the plate hole 3 in the plate is used to secure top end of plate to upper mounting hole in hanger Hope this helps Centre 1 – Centre 2 = 40mm Centre 1 – Centre 3 = 50mm Hole 2 countersunk on one side |
| Author: | Finnpaso [ Fri Oct 03, 2008 6:44 pm ] |
Great! Thiskind i like very much... |
