| tyre pressures http://ducatipaso.org/forum/viewtopic.php?f=1&t=2742 |
| Author: | desmodave [ Mon Sep 22, 2008 11:43 am ] |
| Post subject: | tyre pressures |
what are the correct pressures in p.s.i for the michelins ive seen 33 and 38 somewhere but are these for the pirellis? |
| Author: | amphilex [ Tue Sep 23, 2008 8:56 am ] |
| Post subject: | Re: tyre pressures |
Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi. http://two-wheels.michelin.com/2w/front ... 4a424b424a |
| Author: | Desmo_Demon [ Tue Sep 23, 2008 11:35 am ] |
I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds). |
| Author: | desmodave [ Tue Sep 23, 2008 2:35 pm ] |
| Author: | desmodave [ Tue Sep 23, 2008 2:37 pm ] |
