ducatipaso.org • View topic - different clocks or insrument cluster.
It is currently Fri Mar 06, 2026 2:25 pm
 Post subject: different clocks or insrument cluster.
PostPosted: Fri Feb 13, 2009 1:48 pm
I was wondering if you can change the insrument cluster of another bke or get some other clocks to fit the paso? because of the rubber mounts continuosly breaking off all the time I dont think it would change too much the style of the bike just add to the practical needs as there are issues like carburation, tyres,fuel gauge, lenses need to be adressed still....desmodave
 Post subject: Re: different clocks or insrument cluster.
PostPosted: Fri Feb 13, 2009 3:05 pm
Carbed Monster & SS clocks should work f e.
PostPosted: Fri Feb 13, 2009 3:26 pm
I replaced the M5 rubber mounts by M6. Just drill up the holes, and tap M6 tread in the dashboard. Than drill your head light frame holes to 6mm.
PostPosted: Mon Feb 16, 2009 6:41 pm
I always wondered if it was possible to adapt the instrument panel of an Aprilia RSV Mille (may be possible but also a lot of work) The shape is somehow similar
