It is currently Mon Sep 29, 2025 12:08 pm
[ 4 posts ] |
Author |
renzo750
Post subject: Source for Black Plastic washers... Posted: Tue Mar 24, 2009 2:46 am |
Hello All, Been a long time..guess I finally have something to add.
I discovered Buell Part # BA0409.6BL will get you a nice black plastic washer to use on your Paso body work.
UPDATE: I must apologize for my "quick" post; in side by side measurements the Buell washer is a bit different. The washer, from a Ulysses lower front fender connection: Buell is .8mm thick, 14.25mm OD 6.66mm ID OEM Paso is 1mm thick, 15mm OD and 7.60mmID The hole on the Buell is a tad small to fit the Paso OEM screw; however…with a careful hand it could be made to work.
Jim...Centerville, Mn Orignal owner '87 Paso 750 #1164.
Top |
silverfox
Post subject: Re: Source for Black Plastic washers... Posted: Tue Mar 24, 2009 9:09 pm |
Joined: Thu Jan 06, 2005 12:00 am Posts: 63 Location: Christchurch NZ
Nice one, thanks for the part number but the guy is bound to ask "what's it from?"
Is it a panel screw washer on the Buell?
Tony
Top |
persempre907
Post subject: Re: Source for Black Plastic washers... Posted: Wed Mar 25, 2009 9:46 am |
paso grand pooh-bah |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Have those washers exactly the same measures of the stock ones? I can't stand the transparent ones sold at the Ducati dealers. Ciao
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
Top |
Post subject: Re: Source for Black Plastic washers... Posted: Wed Mar 25, 2009 11:26 am |
Bevel Heaven 10 pack 8 us Bodywork Rubber Washer 10 Pack KL-313197 I am sure there are many others not to mention your local industrial fastener supply house. These are very common parts easy to find
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 54 guests |
