ducatipaso.org :: View topic - A tip for setting correct tension on timing belt?
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=1&t=309
Author:  naster [ Mon Apr 11, 2005 9:50 pm ]
Post subject:  A tip for setting correct tension on timing belt?
I found details of a guy (from the internet) who uses allen keys to set the correct tension on timing belts. Having removed all covers; He writes, "While holding the slack out of the belt, the next step is to insert your 5mm allen wrench between the belt and the fixed roller. It should feel like a feeler gauge does- SLIGHTLY snug."
Note: This is described as general maintenence for dukes. Additionally, its recommend a 6mm allen for the vertical cylinder. (As heat expansion calls for extra slack).
Can we use this method for our Pasos? :confused:
I think this could be a great tip for amateur engineers (like me.)
If anyone is interested in this method: I would recommend visiting the sight first (as other essential details are noted).
See http://www.ducatisuite.com/
It’s a great site, and gives detailed articles with pics for maintenance on every level. From easy (1 tick) to difficult (5 ticks).
Author:  jcslocum [ Tue Apr 12, 2005 1:54 am ]
This is the correct info and I use 5MM for both belts.
Lance has put together a very useful site.
Author:  Skins [ Tue Apr 12, 2005 7:32 am ]
Author:  Duck01 [ Tue Apr 12, 2005 10:41 am ]
Author:  fasterdammit [ Tue Apr 12, 2005 1:00 pm ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
