Open Silentium Exhaust http://ducatipaso.org/forum/viewtopic.php?f=1&t=3169 |
Author: | Mark [ Fri Mar 27, 2009 12:48 pm ] |
Post subject: | Open Silentium Exhaust |
Hello All, Via Windtrading Srl in Italy I'm trying to convince Silmoto to manufacture another set of the following open exhausts from the so-called uprating kit: - 40mm horizontal exhaust pipe 0370.84.023 - 40mm vertical exhaust pipe 0370.84.033 - open right hand exhaust 573.1.003.1A - open left hand exhaust 574.1.003.1A Anybody else interested in a set? Cheers, Mark |
Author: | paso750 [ Fri Mar 27, 2009 1:57 pm ] |
Post subject: | Re: Open Silentium Exhaust |
Hi Mark, do you happen to know the difference between the 0370.84.020 and the 0370.84.023 ? Guess you do if you want to have it made. I`m wondering as the vertical tube 0370.84.033 is used on both headers so they do have the same diameter. Where`s the difference ?! Gerhard |
Author: | Mark [ Wed Apr 01, 2009 7:06 am ] |
Hi Gerhard, I was under the impression that the standard headers have a 36mm diameter. Great news if I only need the open exhausts! Cheers, Mark |
Author: | paso750 [ Wed Apr 01, 2009 7:52 am ] |
check this thread viewtopic.php?f=1&t=3094 G. |
