| problem with starting the bike, relay? http://ducatipaso.org/forum/viewtopic.php?f=1&t=3236 |
Page 1 of 3 |
| Author: | hellogrish [ Sat Apr 18, 2009 8:31 am ] |
| Post subject: | problem with starting the bike, relay? |
hello there, I have some problems with starting the bike, when turning the key on - all the light turn on ![]() but when to press "start" button the engine doesnt start. it helped when I kept holding the "start" button and hitting a little bit relay (the thing that have 2 wide cables - one from battery, and another from elsewhere )but now it doesnt help. to start the bike I have to make "short-circuit" (by connecting these 2 cables for a second) the only way out is to replace relay? any idea where to get this? cheers greg |
| Author: | paso750 [ Sat Apr 18, 2009 9:42 am ] |
| Post subject: | Re: problem with starting the bike, relay? |
your dealer or ebay ? if you need to change it anyway you could try to open it. I found the following instruction longer time ago and translated it from german. I never did try it myself. http://www.box.net/shared/njqjcaortr The relais on later Ducs is a Toshiba which can be used too, but it requires a mounting bracket. You could also adapt a relais from a jap bike if necessary. (then it would be good to know the max. required currect capacity though) G. |
| Author: | jcslocum [ Sat Apr 18, 2009 12:59 pm ] |
Does it crank over if you flip the KILL switch to off and then hit the starter button?? These starting problems are common on the paso and if you look in the FAQ you will find posts aboout this and how to fix it. In the USA we call that BIG relay a "starter Solenoid" . |
| Author: | Finnpaso [ Sat Apr 18, 2009 4:43 pm ] |
| Author: | hellogrish [ Sun Apr 19, 2009 8:25 am ] |
ok, thank guys, eventually there was problem with small cable that goes to the "starter Solenoid" ![]() and after replacing everything work fine.. but... another problem I have noticed that my Paso, how to say, starts (mean move away)a little bitslowly (from the 1st gear), its ok, but some days ago when to starting from crossing, when I get on 1st gear and release the clutch lever - the bike almost didnt move, and it was quite strange noise from the clutch. (not this lovely sound of dry clutch ), then when I moved bike away from the street, get on neutral gearand hold the clutch lever - the noise was really terrible. but just waited some minutes, and came back home without any problems... I am going to have my Paso serviced (as I am not good enough yet ; ) but anyway - what could be that? |
| Author: | paso750 [ Sun Apr 19, 2009 10:20 am ] |
Antti, you`re right. I just remebered it was something japanese Greg, at this point it would be just wild guessing what happened to your clutch. It`s just so much it could be. (from worn clutch discs to other worn or broken parts) |
| Author: | nilaus [ Sun Apr 19, 2009 7:18 pm ] |
I am guessing that it is most likely the bearing in the slave cylinder which is going going going and eventually will be gone. You can get an replacement kit. which will include: bearing, piston and o ring. But the first thing I would do, is to take the clutch lid of and inspect. Happy paso working |
| Author: | Finnpaso [ Mon Apr 20, 2009 2:01 pm ] |
| Author: | hellogrish [ Thu Apr 23, 2009 5:34 pm ] |
hello, got the clutch open, and what I saw was a very thin "driving discs" even some parts of material (they are built from) was missing, and some falled apart when taking out discs.. yep, that means that I have to replace them, but anyway is this a reason that my Paso have problem with fast starting? the clutch is slithering because of old driving discs?cheers greg |
| Author: | hellogrish [ Mon Apr 27, 2009 9:02 pm ] |
nilaus, so what about that replacement kit? any details? I`ve got some leakage from this part of clutch so need to do sth with it... guys, is it easy to be done?
| Author: | jcslocum [ Mon Apr 27, 2009 9:11 pm ] |
| Author: | hellogrish [ Tue Apr 28, 2009 10:27 am ] |
thanks a lot, and do you know sth about driving discs (friction plates) from any other bike? will it fit? as I cannot find for Paso... |
| Author: | streetsurfer [ Tue Apr 28, 2009 6:11 pm ] |
For the start problem, look for voltage drops between the different points in the circuit. I found my largest drops were at the on/off and start switch in my bike. I had replaced the solenoid previously, with no improvement. Cleaning the switches out and their contacts solved the problem. I picked up my solenoid at a yamaha dealer, btw. |
| Author: | hellogrish [ Tue Apr 28, 2009 6:46 pm ] |
I used a search tool found out more and...anybody used friction plates from Suzuki GSF400? |
| Author: | hellogrish [ Fri May 01, 2009 3:29 pm ] |
guys, sorry for being so boring with my problem buy anyway it`s only way to learn sth more... can you take a look at these pictures? I just take clutch cover out, pressed the piston with my hands, got the clutch level hold, and got sth like that: (i cut out my dirty fingers )dont you think that piston should come out more? and here how it all looks: what do you think about it? cheers greg |
| Page 1 of 3 | All times are UTC |
