Problem noise - gearbox? clutch? http://ducatipaso.org/forum/viewtopic.php?f=1&t=3242 |
Author: | silverfox [ Sun Apr 19, 2009 11:32 pm ] |
Post subject: | Problem noise - gearbox? clutch? |
Is it possible to have a broken gear selector spring and for it to "rattle" on hitting a pot hole? It's similar to the noise from the box when you change gear - on decelerating it's a "metallic shudder" It's not anything loose on the bodywork or centrestand or exhaust etc - its from inside It changes gear fine, selects easliy going up and down thru the gears. What are the symptoms of worn gearbox bearings, are there any tests you can do to narrow the problem down? Sorry for being so vague, its hard to locate or describe Tony |
Author: | Brutus [ Mon Apr 20, 2009 12:42 pm ] |
Post subject: | Re: Problem noise - gearbox? clutch? |
Author: | Finnpaso [ Mon Apr 20, 2009 2:21 pm ] |
Pitty, that Your bike is THERE and i cant hear sound, what i coming out... u shuold come here ! ![]() ![]() |
Author: | Tamburinifan [ Tue Apr 21, 2009 1:31 am ] |
