750 paso swing arms http://ducatipaso.org/forum/viewtopic.php?f=1&t=3305 |
Author: | bender [ Sat May 09, 2009 6:13 pm ] |
Post subject: | 750 paso swing arms |
when i was tightening the chain one of the for bolts on the back of the swig arm striped. any ideas on how to fix the problem???? thanks bender.... ![]() ![]() ![]() |
Author: | pasotibbs [ Sat May 09, 2009 7:42 pm ] |
Post subject: | Re: 750 paso swing arms |
Author: | bender [ Sat May 09, 2009 8:23 pm ] |
thanks it is the bottom hole so i will try the "Helicoil" i will let you know how it works. thanks again bender ![]() ![]() |
Author: | nilaus [ Sat May 09, 2009 10:53 pm ] |
I added 3 helicoil in my swing arm last month and when i was at it, I inserted in front fork for the callipers. They where getting to a state, that I was nervous when tightening them. Alloy and steel bolt’s?? there should be a law stating, that you had to insert an helicoil in to a alloy thread ![]() ![]() |
Author: | bender [ Tue May 12, 2009 5:41 pm ] |
sounds like it worked good for you hope that it will work good for me to thanks for you're help with this problem. i will let all of you know thanks bender ![]() ![]() |
Author: | jinshiyang [ Fri May 15, 2009 8:23 am ] |
thanks it is the bottom hole so i will try the "Helicoil" i will let you know how it works. |
