ducatipaso.org :: View topic - Red Paso blues
ducatipaso.org
http://ducatipaso.org/forum/
Red Paso blues
http://ducatipaso.org/forum/viewtopic.php?f=1&t=3340
Author:  Josh [ Thu May 21, 2009 2:08 am ]
Post subject:  Red Paso blues
Hi All,
Great site. Been lurking for a few weeks. Resurrecting the '88 Paso a buddy of mine gave me eight years ago.
Cleaned the carbs, the petcock screen, replaced the hoses, took out the restrictor in the fuel line (return), did the coil upgrade for better voltage (red line to the positive terminal of the battery), new plugs, cleaned stuff - yada yada.
So now when I try to start it, two twists of the throttle, it fires up, then dies no matter what I do to the throttle. If I leave the fuel pump on gas gushes out of the rear cylinder's carb. So can I leave it turned off. Do I need it?
In spite of this post I am actually not a bad backyard mechanic. This has me stumped and I can't bring the bike in or afford to send the carbs out for rebuild. Anyone have the correct float level adjustment info?
Sorry to be a pain, but I really need to start riding.
Thanks,
Josh
Author:  Desmo_Demon [ Thu May 21, 2009 12:29 pm ]
Post subject:  Re: Red Paso blues
Author:  Josh [ Thu May 21, 2009 12:36 pm ]
Can't believe I left that out.
DellOrtos 36 phf. My buddy put them on way back when.
I rode the bike for a bit when I first got it, but it was stalling, backfiring, hard to keep going in stop and go in semi-suburbs where I ride.
Thanks for the info re: fuel pump. Can I plug the bypass return line and just route directly to carbs?
How do you set the float level? Do you think the carb will still flood w/out the pressure from the pump?
Author:  Desmo_Demon [ Thu May 21, 2009 12:43 pm ]
Author:  Desmo_Demon [ Thu May 21, 2009 12:57 pm ]
Here's a link to the functions and set-up of Dellorto carbs...
http://www.ducatimeccanica.com/dellorto ... lorto.html
Here's the page specifically for setting the floats....
http://www.ducatimeccanica.com/dellorto ... o_3_2.html
Carburetor
float position mm
PHBG 16.5 + 15.5
PHBL 24.5 + 23.5
PHBH 24.5 + 23.5
PHBE 18.5 + 17.5
PHF 18.5 + 17.5
PHM 18.5 + 17.5
Author:  jcslocum [ Thu May 21, 2009 3:29 pm ]
The Dell's will gravity feed just fine. No pump needed. the reurn line isn't needed either so you can leave that off as well. Once the plugs are fouled, you need new ones. Get the carbs sorted and change the plugs. You will need to take them apart and use carb cleaner and air peressue to fully clean them out. Old fuel makes a very hard lacquer that plugs stuff up. Change the fuel filter too. Drain the tank and run fresh fuel, get some "Seafoam" and mix it with the fuel. It's an excellent cleaner.
It should start up and run just fine.
Author:  Josh [ Fri May 22, 2009 3:12 pm ]
Thanks for all the help. I'll get some time this weekend to do the work. I'll let you know how it turns out.
You guys are terrific.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
