It is currently Thu Mar 12, 2026 10:46 am
Page 1 of 1
[ 3 posts ] |
| Author |
Message |
silverfox
Post subject: Clutch basket play Posted: Tue May 26, 2009 12:17 am |
Joined: Thu Jan 06, 2005 12:00 am Posts: 63 Location: Christchurch NZ
Hi,
does anyone remember having their clutch plates out and how much sideways play they had in the outer basket? It looks like it has 2? bearings behind it - so I wouldn't expect to have any play?
Do these bearings commonly wear, since they take the load from the engine crank?
Tony
| Top |
silverfox
Post subject: Re: Clutch basket play Posted: Wed Jun 03, 2009 10:47 pm |
Ok, I'll answer my own question
Yes, the primary gear has 2 bearings (spacer and circlip between them) The bearings are 47x25x8 and 47x25x12 with a 47x35x7 seal.
This gear gets a hard time. Its driven via straight cut gears from a cog on the crank and has the clutch basket bolted directly onto it. This is big load and torque for the 2 bearings to cope with, mine need replacing (I'm hoping these are the first bearings in the engine to show wear and that the rest are ok)
now to make a paper side cover gasket.............anyone done this? what about making alloy barrel gasket? (0.4mm)
Tony
| Top |
Post subject: Re: Clutch basket play Posted: Thu Jun 04, 2009 1:33 am |
| paso grand pooh-bah |
The dealer will have the alloy gasket, maybe the paper too.
I have made paper gaskets before but not this thin.
| Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 3 guests |
