| Clutch basket play http://ducatipaso.org/forum/viewtopic.php?f=1&t=3352 |
| Author: | silverfox [ Tue May 26, 2009 12:17 am ] |
| Post subject: | Clutch basket play |
Hi, does anyone remember having their clutch plates out and how much sideways play they had in the outer basket? It looks like it has 2? bearings behind it - so I wouldn't expect to have any play? Do these bearings commonly wear, since they take the load from the engine crank? Tony |
| Author: | silverfox [ Wed Jun 03, 2009 10:47 pm ] |
| Post subject: | Re: Clutch basket play |
Ok, I'll answer my own question Yes, the primary gear has 2 bearings (spacer and circlip between them) The bearings are 47x25x8 and 47x25x12 with a 47x35x7 seal. This gear gets a hard time. Its driven via straight cut gears from a cog on the crank and has the clutch basket bolted directly onto it. This is big load and torque for the 2 bearings to cope with, mine need replacing (I'm hoping these are the first bearings in the engine to show wear and that the rest are ok) now to make a paper side cover gasket.............anyone done this? what about making alloy barrel gasket? (0.4mm) Tony |
| Author: | jcslocum [ Thu Jun 04, 2009 1:33 am ] |
The dealer will have the alloy gasket, maybe the paper too. I have made paper gaskets before but not this thin. |
