| Piston from 750F1 ? http://ducatipaso.org/forum/viewtopic.php?f=1&t=3408 |
| Author: | silverfox [ Wed Jun 17, 2009 11:36 pm ] |
| Post subject: | Piston from 750F1 ? |
Oooops Can you use a piston from a 1985 750 F1 in a 1988 750 Paso? I hate winter maintainance Tony |
| Author: | jcslocum [ Fri Jun 19, 2009 2:11 am ] |
| Post subject: | Re: Piston from 750F1 ? |
You can use a SET of pistons from an F1. You would have to investigate if there is any real difference in the shpe, but a set should work. I think they have the same compression ratio. |
