ducatipaso.org • View topic - Piston please
It is currently Thu Mar 12, 2026 10:21 pm
 Post subject: Piston please
PostPosted: Mon Jun 29, 2009 8:48 pm
anyone know where I can get a 88mm (750) piston? - same as 750F1 and 750ss
will have 093528 cast on the inside.
Or can the ring groove be repaired - broken ring has damaged top and bottom of top groove.
:cry:
Tony
 Post subject: Re: Piston please
PostPosted: Thu Jul 02, 2009 11:12 pm
On ebay now for Cheap! $$
http://cgi.ebay.com/ebaymotors/Ducati-7 ... ccessories
PostPosted: Fri Jul 03, 2009 8:29 am
that`s not the same piston as far as I know. The one for the Paso/Sport are hard to find (at least new ones)
PostPosted: Fri Jul 03, 2009 9:39 am
That's the later "low dome" piston with lower 9:1 or 9.3:1 compression used in early monsters and the early 90s SS.
Same 88mm x 61.5mm bore and stroke but not what I need. :(
750F1, 750 PASO and 750Sport - three models covered 1986-1990 all had the 8mm dome
10:1 compression piston ( 093528 cast on the inside) - thats why Paso's go so well.
Tony
PostPosted: Fri Jul 03, 2009 10:37 pm
Yes, I know there's a diff but didn't want to judge. Ferracci makes a set of pistons for the pantah 750 in 11:1 and I can put you in touch with Bruce Meyer (BCM past owner) and he can make them for you by turingin down a set of 12:1 Wiseco pistons. He has them in stock.
If you want the info, email me at slocumjon AT gmail.com
