ducatipaso.org :: View topic - Piston please
ducatipaso.org
http://ducatipaso.org/forum/
Piston please
http://ducatipaso.org/forum/viewtopic.php?f=1&t=3467
Author:  silverfox [ Mon Jun 29, 2009 8:48 pm ]
Post subject:  Piston please
anyone know where I can get a 88mm (750) piston? - same as 750F1 and 750ss
will have 093528 cast on the inside.
Or can the ring groove be repaired - broken ring has damaged top and bottom of top groove.
:cry:
Tony
Author:  jcslocum [ Thu Jul 02, 2009 11:12 pm ]
Post subject:  Re: Piston please
On ebay now for Cheap! $$
http://cgi.ebay.com/ebaymotors/Ducati-7 ... ccessories
Author:  paso750 [ Fri Jul 03, 2009 8:29 am ]
that`s not the same piston as far as I know. The one for the Paso/Sport are hard to find (at least new ones)
Author:  silverfox [ Fri Jul 03, 2009 9:39 am ]
That's the later "low dome" piston with lower 9:1 or 9.3:1 compression used in early monsters and the early 90s SS.
Same 88mm x 61.5mm bore and stroke but not what I need. :(
750F1, 750 PASO and 750Sport - three models covered 1986-1990 all had the 8mm dome
10:1 compression piston ( 093528 cast on the inside) - thats why Paso's go so well.
Tony
Author:  jcslocum [ Fri Jul 03, 2009 10:37 pm ]
Yes, I know there's a diff but didn't want to judge. Ferracci makes a set of pistons for the pantah 750 in 11:1 and I can put you in touch with Bruce Meyer (BCM past owner) and he can make them for you by turingin down a set of 12:1 Wiseco pistons. He has them in stock.
If you want the info, email me at slocumjon AT gmail.com
Page 1 of 1 All times are UTC
http://www.phpbb.com/
