ducatipaso.org :: View topic - Parts, Parts...
ducatipaso.org
http://ducatipaso.org/forum/
Parts, Parts...
http://ducatipaso.org/forum/viewtopic.php?f=1&t=3553
Author:  PasoRoo [ Tue Aug 11, 2009 12:47 pm ]
Post subject:  Parts, Parts...
Hi Guys,
My local Ducati dealer doesn't have the capability to check any of the older part numbers, so I'm trying to find if there are equivalent parts in the current catalog. Could ayone tell me if there are 'modern' equivalents for the following parts:
Sump plug gasket 22032083A
Filter screen gasket 22032055A
Oil inspection cap 066049183
I suspect the seal in the oil inspection glass is leaking so I would like to replace it. The part list seems to list the cap and the seal as one part number. Does the seal come as a separate part?
Thanks,
Mike
Author:  paso750 [ Tue Aug 11, 2009 1:42 pm ]
Post subject:  Re: Parts, Parts...
22032055A is now 78710091A and used ie on the 916.
22032083A is also used for SS, ST, Monster, Hypermotard, 748 - 999 etc.
Author:  Desmo_Demon [ Tue Aug 11, 2009 6:53 pm ]
Author:  PasoRoo [ Wed Aug 12, 2009 1:24 pm ]
I'm always amazed how much knowledge floats around in this forum, fantastic! With these new part numbers I should be able to get the gaskets sorted.
Desmo: I had a read of the threads on the oil glass and I understand that I need to look for used parts or check out the German seller on Ebay. However, can you tell me if the glass consists of a screwcap and a seal, or is it a different construction? If it is the former, I'm wondering what the risk is with buying a used one. I'm a bit hesitant to take the oil glass off the bike before I've got replacement parts, so I'm trying to figure out what it looks like before unscrewing anything.
Thanks again,
Mike
Author:  Desmo_Demon [ Wed Aug 12, 2009 8:01 pm ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
